BOPP薄膜生产线的CC-Link现场总线控制系统
DISTRIBUTED CONTROL SYSTEM BASED ON CC-LINK FIELDBUS IN THE BOPP FILM PRODUCT LINE LI Zhong1,2, LI Yan2, YU Meng-hong2, CHEN Hong-wei2 , HE Zu-jun2 (Dept. of Electronics and Information, East China Shipbuilding Institute, Zhenjiang 212003 China) Abstract The paper introduces a distributed control system based on CC-Link fieldbus in the BOPP film product line. Mitsubishi Q02CPU PLC is used in the system and 590 series controller is used as its DC driver. Several measured signals are transmitted to PLC via CC-Link and distributed I/O modules such as AJ65SBTB1-16D, FX2N-32CCL, etc. In this paper the process of BOPP film production and the characteristic of CC-Link are introduced. Because the product line is continued working, its devices are spread around 80 meters, and its controlled process is complex. For above reasons, the distributed control system is consisted of 4 subsystems with relative independent function. Viz. the speed chain drive control system, the temperature control system, the film thick measured system and the auxiliary control system. The actual application shows that the distributed control system is simple, reliable and good real-time. There is a powerful demonstration for the its further application. KEY WORDS fieldbus; CC-Link; distributed control; BOPP; PLC; IPC; single-chip microcomputer 摘要 本文介绍了一种BOPP薄膜生产线的CC-Link现场总线集散控制系统,系统采用三菱Q02CPU PLC,直流传动采用590系列直流调速器,多种检测信号通过分布式I/O组件AJ65SBTB1-16D、FX2N-32CCL等,经由 CC-Link传送至PLC。文中简要介绍了BOPP薄膜生产过程及CC-Link结构特点,由于该生产线连续作业,设备分布较分散约80米,控制过程较为复杂,因此整个集散控制系统在功能上由4个相对独立的子系统组成,即速度链传动控制系统、温控系统、测厚系统及辅助控制系统。实际应用表明该系统简洁、可靠,实时性强,为今后进一步的应用提供了有力实证。 关键词 现场总线;CC-Link;集散控制;BOPP;PLC;工控机;单片机 中图分类号 TP273,TP391 文献标识码:A 1 引言 BOPP是Biaxial Oriented PolyPropylene (双向拉伸聚丙烯)的缩写,BOPP薄膜具有拉伸强度大,透明度高,保鲜性好、光泽明亮、彩印鲜艳、外观装饰华贵等优点,而且还具有很高的机械强度和附着力以及极好的化学性和良好的化学稳定性(与名种酸、碱、盐不发生化学反应),耐水耐热,是一种高级塑料包装材料,广泛应用于香烟、服装、食品、印刷品等、也可做粘胶带基及电容器的电介质。 BOPP薄膜生产线工作原理是:根据薄膜生产工艺要求,将挤出机及机头的各节筒体分别加热到不同的工作点,按配方通过料斗不断地注入料粒;熔融状的物料由机头挤出后,经过冷却辊冷却,形成窄而厚的薄膜厚片;薄膜厚片经过储片架整理后,被送入纵向拉伸区,根据工艺要求由慢速辊和快速辊进行2.5~5.0倍的纵向拉伸处理;横向拉伸区用于实现薄膜的第二次拉伸,即横向拉伸,该区域涉及薄膜的横拉分区加热控制、同步传动控制、破膜检测及其处理等问题,是实现有效成膜的关键之一;薄膜经过双向拉伸(即纵拉和横拉)后,被送入后处理区域进行后续工艺的处理,再经过上卷辊整理,由两台收卷辊轮换进行恒张力收卷,最终形成成品膜。
BOPP薄膜生产线全长约80米,如图1所示,其中主要包括1:挤出机及机头系统;2:冷辊装置;3:前扫描测厚装置;4:储片架;5:纵向拉伸区域;6:横向拉伸区域;7:横拉辊装置;8:后处理区域;9:后扫描测厚装置;10:上卷辊装置;11:收卷区域。 为了进一步提高控制系统的可靠性和自动化程度,便于系统功能的扩充,提出在原有生产设备的基础上采用CC-Link现场总线等技术对控制系统进行改造。建立起由PLC、分布式控制模块、工控机、单片机及智能仪表组成的集散控制系统,以实现对生产线的集散控制、工艺曲线的实时显示、关键参数的存储等,便于生产管理和提高产品质量。 2 集散控制系统结构设计 2.1 CC-Link开放式现场总线 CC-Link是Control & Communication Link(控制与通信链路系统)的简称,是三菱电机于1996年推出的开放式现场总线,其数据容量大,通信速度可多级选择,最高达10Mbps。它是一个复合的、开放的、适应性强的网络系统,能够适应于较高的管理层网络到较低的传感器层网络的不同范围[1]。CC-Link是一个以设备层为主的网络,整个一层网络可由一个主站和六十四个从站组成。网络中的主站由PLC担当,从站可以是远程I/O模块、特殊功能模块、带有CPU和PLC本地站、人机界面、变频器及各种测量仪表、阀门等现场仪表设备。采用第三方厂商生产的网关还可以实现从CC-Link到ASI总线的连接。
CC-Link的底层通信协议遵循RS485,一般情况下,CC-Link主要采用广播轮询的方式进行通信,CC-Link也支持主站与本地站、智能设备站之间的瞬间通信[2]。具体方式为:主站将刷新数据RY/RWw发送到所有从站,与此同时轮询从站1;从站1对来自主站的轮询作出响应RX/RWr,并将该响应同时告知其它从站;然后主站轮询从站2(此时并不发送刷新数据),从站2给出响应,并将该响应告知其它从站;依次类推,不断循环,图2所示为广播轮询时的数据传输帧格式。除了广播轮询式的循环通讯方式外,CC-Link还提供主站、本地站及智能设备站之间的信息瞬时传送功能。信息从主站传递到从站,信息数据将以150字节为单位分割,并以150字节传递。若从从站传递到主站,每批信息数据最大为34字节。瞬时传送需由专门指令来完成,但不会影响循环通讯的时间。 2.2 集散控制系统结构 考虑到BOPP薄膜的生产工艺特点及其复杂性等因素,本文设计并构造的集散控制系统结构如图3所示。在该CC-Link现场总线网上,Q02CPU是主站,QJ61BT11作为接口
模块。从站有两大类:一类是远程I/O站,由AJ65BTB2-16R和AJ65SBTB1-16D远程I/O模块组成,共8个模块,每个模块占用1个逻辑从站资源,主要用于实现对各直流调速电机的起停、切换、联锁、故障等控制和检测;另一类由FX2N-32CCL和A80BDE-J61BT13远程设备模块构成,共5个模块,考虑到所要传输的信息量较大,在这里每个模块被设计成占用4个逻辑从站资源,主要用于实现与FX2N-80MR PLC和工控机的连接[3]。因此,整个CC-Link网络由一个主站和28个逻辑从站构成。 该集散控制系统除了应用CC-Link网络外,还采用了其它通讯网络方式对系统各局部区域进行控制,如RS-422、RS-485等。 前部传动控制用FX2N-80MR PLC(从站9#~12#)通过FX2N-485BD板卡,采用RS-422网络对挤出机、冷辊电机、慢速辊电机、快速辊电机和横拉辊电机共5台直流电机进行控制与检测;后部传动控制用FX2N-80MR PLC(从站17#~20#)采用相同的RS-422方式对后处理电机、上卷辊电机、收卷1电机和收卷2电机共4台直流电机进行控制与检测,它们共同实现对速度链传动控制子系统的控制。此外,位于前操控台的FX2N-80MR PLC(从站13#~16#)和位于后操控台的FX2N-80MR PLC(从站21#~24#)分别通过其RS-422编程口与各自的单片机系统相连,用于实现调速电机的速度设定、速度显示、调速器内部状态监测等。 工控机IPC1(从站25#~28#)采用RS-485通讯网络,通过CD901智能仪表对整个温控子系统进行实时监测与控制,该温控子系统包括对挤出机、机头、纵向拉伸和横向拉伸共34个独立的加热区的温度控制。另外,位于后操控台的FX2N-80MR PLC(从站21#~24#)还通过FX2N-485BD板卡,采用RS-485通讯方式与张力控制器LE-40MTB相连,用于实现对薄膜左、右张力的检测与恒张力收卷控制。 工控机IPC1还有一个重要的任务就是控制并驱动前扫描测厚装置,检测并显示薄膜厚片的厚度,以及显示传动子系统、温控子系统的关键工艺参数情况,便于工艺技术人员及时调整相关参数,保证产品质量。工控机IPC2主要用于控制、驱动后扫描测厚装置,检测并显示成品膜的厚度,产品的最终公差分布情况在这里得到充分的体现。IPC1与IPC2被置于同一个电控柜中,由于距离相隔很近,因此采用RS-232C通讯方式将它们连接起来,进行数据共享。这两台工控机共同构成了薄膜测厚子系统。 2.3 一个集散控制流程简例 图4所示是该集散控制系统对其中的后处理电机进行控制的过程,图中2、3、6、7、9表示CC-Link网络,1和8表示从站(21#~24#)通过其RS-422编程口与单片机进行数据交换,4和5表示从站(17#~20#)通过其485BD板卡与直流调速器进行RS-422数据通
讯。来自码盘的数值经1、2、3、4传输后,进入DC调速器6,作为后处理电机的速度设定值,该调速器与光码共同组成一个独立的转速闭环控制系统。另外,后处理电机的实际转速值经5、6、7、8传输后,转换为当前的薄膜生产线的线速度,由LED显示出来,供操作人员使用,同时该线速度还经由9被传输至IPC1,供工艺技术人员集中使用。 3 集散控制子系统设计 由于BOPP薄膜生产线的生产工艺复杂、生产设备及种类繁多、安装地点较为分散,因此该集散控制系统涉及多CPU类型(PLC、IPC、单片机)、多种通讯网络结构(CC-Link、RS-422、RS-485、RS-232C),它们共同组成一个有机的整体。本
向“新”而行 三菱电机携重磅新品亮相ITES
半导体市场回暖 三菱电机多套解决方案全面应对
从简单加工到高端制造 三菱电机助力毅兴智能华丽蜕变
中国首发!三菱电机新型数控系统让制造更智能
三菱电机深化长三角产教研城融合,增强跨区数智化合作
