奥康(AuCom)软起动器在欧洲隧道中(水泵)的应用
2008/10/13 0:00:00
解决方案
The engineers sought a high-quality solution to control all pumping processes during excavation. In an international tender process, AuCom won the contract to supply electronic soft starters controlling the many 700 V, 310 kW submersible pumps needed to drain the tunnel as digging progressed.-->
工程师找出了一个高质量的解决方案来控制开挖过程中的所有抽水过程。在国际招标过程中,AuCom最终投标成功,赢得电子软起动器的供应合同;这些设施将用来控制隧道开挖中的多个700伏、310千瓦排水潜水泵。
AuCom was selected for this project ahead of its competitors for three good reasons:-->
由于以下三个主要原因,AuCom在该工程中被选定为供应商:
- 经验。AuCom在电子软起动领域具有多年的经验,在泵送行业具有行业认可的可靠性和工程质量声誉。
- 产品系列。 AuCom提供多类型、多用途的解决方案。AuCom的低压解决方案可用于高达1000伏、50赫兹或60赫兹的供电电压,适合与1马力到2000马力电机匹配使用。
- 服务。AuCom提供绝对一流客户服务。公司在全世界范围都设有办事机构,并在隧道施工中提供全面现场支持。
效益
Soft starting provides important operating benefits in the tunnel environment.-->
软起动在隧道环境中提供重要的操作优势。
电流水平降低
Electronic soft starting reduces current levels during starting. Closed loop electronic soft starters enable motors to be started with the minimum possible start current required for the application. This reduces voltage disturbance which is important for weak or limited supplies.-->
电子软起动在起动过程中可降低电流水平。闭合回路电子软起动器确保电机以具体应用场合所需的最小可能起动电流进行起动,从而降低对弱电供应或有限电力供应的电压干扰。
卡泵
Soft starters prevent damage if the pump stalls or jams. Instead of stepping through to full voltage and subjecting the stalled pump and motor to damaging electrical and mechanical stresses, AuCom electronic soft starters will shut the plant down safely.-->
泵失速或卡泵时软起动器可防止设备损坏。AuCom电子软起动器确保装置安全关闭,使失速泵和电机不因满电压而受到破坏性电气或机械应力的影响。
液锤
When pumps suddenly stop, damage may occur from water or fluid hammer. AuCom soft starters offer a soft stop facility which ramps down the voltage supplied to the motor, causing a gentle decrease in pump and fluid velocity which in turn reduces the possibility of damage.-->
突然停泵时,可因水锤或液锤作用而导致设备损坏。AuCom软起动器提供一个软停车设施,该设施可降低施加于电机的电压,从而实现泵和液体速度柔和降低,进一步降低了设备损坏的可能性。
保护功能
AuCom soft starters offer additional protection features which make them the obvious choice:-->
AuCom软起动器提供辅助保护功能,因而成为用户显而易见的明智选择:
- reverse rotation protection 反向旋转保护
- motor over-temperature protection 电机过热保护
- overcurrent protection 过载电流保护
- phase loss protection 失相保护
- undercurrent protection 低电流保护-->
- 反向旋转保护
- 电机过热保护
- 过载电流保护
- 失相保护
- 低电流保护
AuCom的其他泵送装置解决方案
- · Swire Properties City Centre Complex, Hong Kong - AuCom soft start and soft stop eliminates piping damage caused by fluid hammer. -->
- 香港Swire Properties市中心建筑群:AuCom软起动和软停车消除了液锤作用对管道系统的损坏。
- Canterbury, New Zealand - soft start ensures large irrigation pumps can operate successfully at remote locations with limited electrical supply. -->新西兰Canterbury:软起动确保大型灌溉系统可在电力供应有限的边远地区成功运转。
- Mt Buller Ski Field, Victoria, Australia - soft start minimises generator set requirements for snow making pumps. -->澳大利亚维多利亚Mt Buller Ski Field:软起动可最大限度降低造雪泵对发电机组的要求。
这些仅仅是在诸多在泵送应用场合中采用AuCom软起动器装置的部分实例。如果您需要为电机控制提供一个设计方案,请与我们联系。
奥康软起动器在菲律宾市政供水应用
欧瑞变频器在塑料印刷机械收卷设备上的应用
欧瑞变频器在线切割机床的应用
