SAMC电机应用于硬盘自动化组装
SAMC电机应用于硬盘自动化组装
April 2009
FOR IMMEDIATE RELEASE
 News Release
 SMAC Moving Coil Actuators(SMAC移动式线圈致动器)
 implifies disc drive assembly system - replacing three devices with one linear rotary actuator.
简化系统 : 使用一台的线性旋转致动器,取代原来3台的设备.
The use of the SMAC linear rotary actuator for a screwdriver has expanded to disc drive assembly.
SMAC音圈电机用于玻璃切割或划线设备
SMAC音圈电机在手机制造机械化检测系统的应用
SMAC致动器用于燃料杆量测
LCA25系列音圈电机
SMAC LCA25系列音圈电机
