改进的邻近效应计算
改进的邻近效应计算
2011/6/13 0:33:00
Abstract—The two best-known methods for calculating highfrequency winding loss in round-wire windings—the Dowell method and the Ferreira method—give significantly different results at high frequency. We apply 2-D finite-element method (FEM) simulations to evaluate the accuracy of each method for predicting proximity-effect losses. We find that both methods can have substantial errors, exceeding 60%. The Ferreira method, which is based on the exact Bessel-function solution for the eddy current in an isolated conducting cylinder subjected to a timevarying magnetic field, is found to be most accurate for loosely packed windings, whereas the Dowell method, which approximates winding layers comprising multiple turns of round wire with a rectangular conducting sheet, is most accurate for closely-packed windings. To achieve higher accuracy than is possible with either method alone, we introduce a new formula, based on modifying the Dowell method. Parameters in the new formula are chosen based on fitting our FEM simulation data. By expressing the results in terms of normalized parameters, we construct a model that can be used to determine proximit
PLC一体机之EK温度修正使用技巧
S7-300CPU存储器介绍及存储卡使用
0.05级超高精度互感器
DC-DC转换器(电源模块)应用指南——外接滤波电容选配
施罗德最小流量阀的应用范围及优点
