电子化制造的介绍
摘要
本文介绍了电子化制造技术,其技术策略、基本要素和实现从制造业向电子商务环境转变的要求。电子化制造是一个使得制造实现基于预测的零故障性能,以及通过网络及非接触式(如无线,网络等)信息电子技术同步商业系统的变革性系统。电子化制造集成了(机器和生产过程层级的)数据流,(工厂和供应系统层级的)信息流和(商业系统层级的)现金流的信息和决策。这一转变取决于“电子工厂”和“电子自动化”的下一代生产操作的进步,旨在在全局基础上通过信息利用实现目标。
Introduction to e-Manufacturing
Abstract
This paper gives an introduction about e-Manufacturing strategies, its fundamental elements and requirements to meet the changing needs of the manufacturing industry in transition to an e-business environment. Briefly speaking, e-Manufacturing is a transformation system that enables the manufacturing operations to achieve predictive near-zero-downtime performance as well as to synchronize with the business systems through the use of web-enabled and tether-free (i.e. wireless, web, etc.) infotronics technologies. It integrates information and decisions in data flow (of machine/process level), information level (of factory and supply system level), and cash flow (of business system level). This transition is dependent upon the advancement of next-generation manufacturing practices on "e-factory and e-automation" which is focused on the use of information to make things happen collaboratively on a global basis.
美国智能维护中心- 丰田汽车制造公司(TMMK,肯塔基州)机器人诊断及预测案例
美国智能维护中心 -宝洁公司案例
美国智能维护中心 -欧姆龙项目
美国智能维护中心 - TECHSOLVE公司智能机床健康维护项目
智能维护技术
