瑞奇能电容式传感器用于撒盐车上盐位的限位监控
        瑞奇能的电容式传感器用于一系列多用途运载车和有轨车辆上的各种各样的测量任务。这个系列的传感器甚至在极端恶劣的环境中也能准确稳定运行。对于多用途运载车上的电容式传感器用于公路盐位(撒盐车上盐位),冷凝液,各类油品等等进行限位监控。对于有轨车辆上的应用它们是安全领域的监控,称为“dead man function”。对于火车上的对饮用水和污水的水位监控也是用电容式传感器实现的。
        Rechner’s capacitive sensors are used for various tasks within a range of utility vehicles and rail vehicles. They operate correctly and are reliable even under extreme conditions. With utility vehicles the capacitive sensors serve as level control for the road salt, condensate liquids, oils, etc. With rail vehicles they are used in the area of safety in the so-called dead man function. The level control of the water storage containers in trains is also achieved with capacitive sensors.
        我们可以为客户提供各种尺寸和不同材质外壳的电容式传感器。
These sensors are available in a variety of different versions and housing materials.
Data sheet:  http://www.rechner.de/en/suche/index.php?nummer=818600
展会直击|华南国际工业博览会
展会直击|2024SNEC上海光伏展
科瑞RFID与IO-Link技术智能结合产品
电感传感器:智能回转 精准定位
科瑞漏液检测光电RL25系列
