称重传感器应用在液压/气压机械工程
2012/9/27 15:40:24
Hydraulic / Pneumatic Press Force Verification / Calibration液压/气压机械工程
Products In Use
Column Load Cells or Load Buttons (LCA/LLB Series) paired with USB Solutions.View Product Details柱式/单点型力传感器(LCA/LLB系列),FUTEK USB传感技术解决方案
Application Summary
Press (Hydraulic or Pneumatic) verification testing is a necessary requirement within the automation process. By implementing load cells with USB output, the operator can verify the uniform loading of a large platform. Each load cell serves as a monitoring point within the system.压力(液压或气压)均衡性试验是自动化过程控制的必然要求。通过在压力机横梁下均布带USB输出的力传感器,每一只力传感器充当一个监测点,这样我们的工程师可以知道压力机横梁的施加力是否均匀一致。
How it Works
1. In this application, engineers have installed several LCA or LLB Series Load Cells at the base of this hydraulic press. (Implement enough load cells to quantify the full force capacity of the press)在这个应用当中,LCA或LLB系列力传感器安装在压力机横梁底下,保证力传感器的数量足够多,确保力传感器足以抗衡压力机的压力。
2. These load cells have been paired with FUTEK's USB modules to stream live measurements onto the engineer's PC.力传感器带USB接口输出,连接到电脑上,实时监测施加力的变化。
3. As compressive forces are applied to the LCA/LLB Series Load Cells, FUTEK's USB modules in conjunction with FUTEK's SENSIT Test and Measurement Software can verify if the hydraulic press is accurately performing.当压力机向LCA/LLB传感器施压时,FUTEK的USB A/D模块与SENSIT Test and Measurement软件正实时监测压力机横梁底下的施加力。
Products In Use
美国 Dytran 1060C 压电式力传感器-电荷型
美国 Futek TRH600 旋转式(动态)扭矩传感器
美国 Dytran 7500A2 电容(DC)型加速度传感器
美国 Dytran 1210C2 压电式力传感器-电荷型
美国 Dytran 1051C 压电式力传感器-电荷型
