称重传感器应用在液压液位控制器
2012/9/27 16:24:15
中空型/轮辐式力传感器(LTH系列与LCF系列)及相关显示仪表(IPM650与IHH500),View Product Details
Application Summary
Implementing load cells and instrumentation can automate multiple systems within tank dispensing applications. This process ensures operators precision measurements in liquid ratios and triggers for valve opening and closing.称重传感器及其相关仪表可应用在药剂自动调配当中,实现药剂槽罐中液位的精确控制和阀门的开关。
How it Works
1. In this particular application, specific ratios of each liquid must be dispensed into mixing container prior to its release into each jar.在该应用当中,药剂在倒进空瓶之前,各种一定比例的液体必须在槽罐中均匀混合。
2. To ensure that these liquids ratios are exact, a LTH/LCF Series Load Cell has been installed at the base of each liquid dispensing container.LTH/LCF系列称重传感器安装在各个液体槽罐底部,这样可以控制各种液体混合的比例。
3. Each load cell has been paired with either FUTEK's IHH500 Handheld Display or IPM650 Panel Meter. These instruments will monitor the readings of the load cells.每一只传感器与IHH500手持式显仪或IPM650数显仪表组合工作,这些仪表可实时显示传感器的力值。
4. Once a specific ratio of liquid has been released from the container, the IHH500 or IPM650 will trigger the control valve to close.当一定比例的液体从槽罐中流出,IHH500或IPM650仪表发出触发信号,控制阀门关闭。
5. Then the contents in the mixing container can be released into the jar below.药剂均匀混合后,释放到下面的空瓶中。
6. Implementing these load cells and instruments allows the operator to automate this system with precision and efficiency.FUTEK称重传感器及其相关仪表在该应用当中,使得整个调剂过程精确可控。
Products In Use
美国 Dytran 1060C 压电式力传感器-电荷型
美国 Futek TRH600 旋转式(动态)扭矩传感器
美国 Dytran 7500A2 电容(DC)型加速度传感器
美国 Dytran 1210C2 压电式力传感器-电荷型
美国 Dytran 1051C 压电式力传感器-电荷型
