为什么要测量扭矩?
为什么我需要测量转矩和功率? 为什么它如此重要呢?
这个问题很好! 我的答案很简单: “因为它可以节省时间和金钱。”
这里有一些在时间和金钱方面的原因,更重要准确测量出机械旋转轴的扭矩和功率。
“Why do I need to measure torque and power? Why is it important?”
Great questions! My simple answer: “Because it saves time and money.”
Here are some reasons, in terms of time and money, why it is important to measure true mechanical Torque & Power on rotating shafts.
1.优化航海燃料效率 - 验证准确的引擎功率输出 (s)。准确测量功率输出非常重要,是推进效率分析和排放分析的关键。需要将燃料输入、功率输出以及船舶的速度进行对比。
1. Optimize Fuel Efficiency, Marine – Verify the true Power output of the engine(s). The true Power output is critical in the propulsion efficiency analysis and emissions analysis. Compare Fuel Input to Power Output to Vessel Speed.
2.负载管理 - 持续监测材料负载,我们可以在加速或减速的过程中测得驱动轴上的扭矩,因此,即使在材料堵塞可能导致设备停下的过程中,我们也可以及时拿到数据,使设备发生故障前尽快采取措 施。响应时间:最大2ms。
2. Load Management – Continuously monitor the material load, as indicated by the Torque on the drive shaft, and speed up or slow down the process accordingly; even stop the process altogether in the case of a material jam, before any damage can occur to the equipment. Response Time: 2 msec max.
3.高/低扭矩预警 – 持续监测轴扭矩,以确保负载保持在安全操作范围内,从而防止疲劳/或设备故障。
3. High/Low Torque Alarm – Continuously monitor the shaft Torque to make sure the load stays within safe operating limits, thereby preventing premature fatigue and/or failure of the equipment.
4.诊断 - 了解实际需要的机械功率大小。了解为什么有嗡嗡声(扭振)。了解为什么联轴器断裂(过高的启动扭矩)。
4. Diagnostics – Learn how much mechanical Power (Hp or kW) is truly needed to accomplish a task. Learn why there is a humming noise (torsional vibration.) Learn why the coupling broke (excessive start-up torque.)
5.定期检修 - 扭振动的诊断或消除需要定期检测,否则会导致疲劳和/或设备故障。
5. Preventive Maintenance – Diagnose and eliminate a torsional vibration condition that, if left unchecked, will result in premature fatigue and/or failure of the equipment.
以上这些都是为什么要测量扭矩和功率,也是为什么扭矩和功率的测量能为大家节省时间和金钱。目前TorqueTrak仪器已应用于世界各地许多不同的行业中。
These are some of the basic ways Torque & Power measurement can save time and money for just about any operation where there is a rotating shaft. The TorqueTrak instruments are used in many different industries and applications all around the world.
如果有什么问题,您可以随时联系我们。
Typical Applications: http://www.binsfeld.com/index.php/applications/.Please feel free to contact me anytime for assistance. Thank you.
很明显,扭矩和功率测量已获得很好的赞誉。为什么如此重要?它将如何节省费用呢?我已在今天的简报中列出了一些想法。我很乐意随时与您进一步讨论。
It has become apparent that the value of Torque & Power measurement needs to be explained better. Why is it important? How will it result in a cost savings? I have given some ideas in today's newsletter. And I will be happy to discuss further with you anytime.
如果您有好的应用或成功案例是涉及到TorqueTrak仪器,并愿意与大家分享,请联系我们,谢谢您的支持。
If you have a good application or success story involving the TorqueTrak instruments that you would like to share in this newsletter, please send it to me for consideration. Thank you.
Bob Holden
Sales Manager
Chart HALT/HASS试验箱解决方案特点介绍
Chart真空绝热管道
电池管理系统测试平台
动力电池充放电系统
直流马达测试方案
