穆尔最新推出MCT/MET变压器 - 全系列认证变压器
德国MURRELEKTRONIK在中国全系列生产MST/MET系列变压器。其功率可以含盖40VA至5000VA。
快速安装更节约成本
全新DIN导轨安装或锁孔安装使您的安装时间减少到最少。 有效提高您的生产效率,降低生产成本。
适合您全球战略的产品
全球化认证CE,UL,cUL使您的产品可以畅通无阻的在全球范围内使用。我们在全球的分支机构将为您提供保修。我们同样可以为我们客户提供具有CE、U、cUL认证的特殊抽头变压器。
通用和灵活
输入230/400 输出24和230的系列将作为标准产品,并我们会备有大量库存满足您的生产需要。
Save time and cost through quick assembly
The top hat rail mounting reduces assembly time considerably, avoiding costly and time-consuming assembly with drilling jigs, drilling and screwing. Time and costs are therefore significantly reduced.
Accreditation for the world market
The fulfilment of national and international standards, as well as CE, UL and cUL certificates are standard and allow the worldwide usage of transformers.,
Modules with customer specific input and output voltage (as well as multiple voltages) are also available on demand. These specially designed transformers are also CE, UL, and cUL certified.
Flexible and Universal
The double winding on the primary side of every transformer in the MTS line can be used for a voltage of 230 and 400 V. The same transformer can be used for different applications and storage costs and the variety of parts can be reduced. All standard models are available in stock.
穆尔自动化系统IP67紧凑模块 MVK-MP
穆尔自动化系统 ASI总线设备MVK8
穆尔自动化系统IP67紧凑模块 MVK-P
穆尔自动化系统 ASI总线设备MVK12
穆尔自动化系统IP67紧凑模块 MVK-I
