艾讯宏达 最新推出UFO6368S 无风扇嵌入式计算机系统
UFO6368S
AMD Geode Castle Fanless System w/VGA/Audio/1394/CF/Mini-PCI/LANx2
FEATURES:
� Supports AMD Geode LX800 400/500 MHz with 128 KB L2 cache
� AMD Geode⑩ CS5536 companion chip
� Dual 10/100 Fast Ethernet LAN Ports (VIA VT6105)
� USB 2.0 x 4/VGA/IEEE 1394/Audio Out interface
� Onboard Mini-PCI socket for Wireless LAN connection
� 4 Serial Ports with RS232 support only
SPECIFICATIONS:
� Construction Aluminum chassis with fanless Design
� Dimension 195 mm (W) x 150 mm (D) x 80 mm (H)
� Mainboard Supports AMD Geode LX800 500 MHz with 128 KB L2 cache;
AMD Geode CS5536 companion chipn;
AMD Geode Castle 500MHz w/ 128KB L2 cache
� Main Memory Supports one 184-pin Non-ECC Non-Registered DDR DIMM, Max up to 1 GB
� Device n On-board CompactFlash socket x 1;
Internal 2.5” HDD drive bay x 1;
� Expansion Slot PC/104-Plus (without -12 V and -5 V);
Mini-PCI Socket x 1;
� I/O Interface Front I/O Ports;
HDD Access/Power/LAN status LED (Act/Link; Speed);
Programmable Alarm LED;
Programmable Status LED;
USB 2.0 x 4 portsn Serial port x 2;
Rear I/O Ports;
Parallel port x 1;
PS/2 Keyboard/Mouse x 1;
IEEE1394 port x 1;
Serial port x 2;
Audio out x 1;
10/100 Ethernet LAN x 2;
VGA connector x 1;
DC power 12 V input x 1
�Operating temperature: 0∑C to 40∑
�Relative humidity: 10% to 90% (Non-condensing)
艾讯宏达金典产品选型目录
艾讯宏达i5系列工业平板电脑PAD6315-i54C
艾讯宏达环保专用平板电脑PAD6315-BTHB
艾讯宏达嵌入式无风扇主机助力搬运机器人的发展
艾讯宏达支持双ISA的B85芯片组ATX主板
