Banner推出一款新型超声波传感器S25U112L30
Banner的超声波家族又添新产品了,那就是具有智能温度补偿的新型传感器特殊型号超声波传感器。检测距离150mm ~ 1000mm。
智能温度补偿传感器技术参数如下:
1. 检测距离: 100mm ~ 1000mm
2. 分辨率: 1mm
3. 盲区信号: 高电平
4. 输出: NPN OC门
5. 电源: 10~30vdc
6. 温度:
- 操作 0 ~ 70�C
- 储存 -15 ~ 50 �C
英文资料如下:
The non-contact height sensor types that are used in the road pavement measurement today are either laser, ultrasonic, optical or infrared. Ultrasonic sensors were the most common type of sensors used in the 1980s. Currently laser sensors are the most commonly used height sensors used in profilers. However, because of the economic cost with this type of sensors, their use has increased over the past several years in China.
The ultrasonic sensors record the height to the pavement surface from the vehicle. The accelerometers that are located on top of the ultrasonic sensors record the vertical acceleration of the vehicle. Data from the accelerometers are used to determine the height of the vehicle relative to an inertial reference frame. The distance measuring system keeps track of the distance with respect to a reference starting point. Using the data recorded by the distance measuring system, height sensor and the accelerometer, a computer programme computes the profile of the pavement surface.
应用图
应用图
防患于未然!如何轻松把握汽车总装车间的“脉搏”?
新品速递丨精确定位+多测量模式——邦纳EG24高精度边缘测量传感器重磅发布
预测性运维,降低维护成本!看邦纳无线振动如何实时远程把“脉”电机状态
新品速递丨邦纳QS18LAF400IR 背景抑制型红外激光传感器重磅发布
邦纳大中华区新高管团队亮相:深耕中国市场,引领业务新篇章
