亚华兴推出手持轻薄平板电脑YHX-8080
处理器/芯片 |
Z510P 1.1GHz, 512K Cache, 400MHz FSB; Z530P 1.6GHz, 512K Cache, 533MHz FSB; |
内存 |
1 x 200-pin SO-DDR2 DIMM socket, up to 2GB 400/533MHz SO-DDR2 |
存储 |
CF Card Slot, parallel ATA slave SD Card Slot for SD/SD 2.0/MMC Card |
显示器 |
8.4"TFT Analog VGA,SVGA 800x600,Digital LVDS 4-wire resistive touch panel,可选配户外可阅读屏幕 |
分辨率 |
800*600 |
I/O接口 |
2 x USB 2.0 Type-A Connector 2 x RS 2 x RS VGA D-Sub Connector Earphone Jack DC Input Jack |
通讯接口 |
One Mini-PCIe Card Slot for HSDPA One USIM Card Slot |
系统BIOS |
电源支持 |
AC: 60 Watts Switching Power Adapter, UL/CE/PSE Certified Input: 100-240V AC, Output 12V DC, DC: 7.4V / 3600mAH Li-ion Rechargeable |
操作系统 |
Windows 7™, Windows Vista™, XP/2000/NT4.0/ME/9x, Linux® |
温度范围 |
Ambient Temperature: 0º C - 50º C (operating), -10º C - 60º C(Storage) |
尺寸 |
203(H) x 267(W) x 40(D)mm |
亚华兴 磁盘阵列加速卡
亚华兴 防爆摄像机
亚华兴 蓝牙信标
亚华兴YHX-215EC防爆计算机
AI的绝配——高速磁盘阵列卡GRAID
