Trio运动控制器新系列--MC405运动控制功能
MC405是一款高性能的运动协调控制器,其使用性能强劲的ARM11处理器,能够提供四个伺服轴并加一个主编码器轴的配置控制方案,或者也可以实现五个步进轴方式的控制。所有的五个编码器端口都可以做为普通增量编码器接口,并且其中的任何一个编码器端口还可以被配置为常用的绝对值编码器类型,可以连接SSI,Tamagawa或者Endat等绝对值编码器。此外第五轴可以被用做步进轴、参考编码器输入或者同步编码器输出等功能。
MC405具有16个轴的软件功能,任何没有被分配到实际物理轴的轴都可以被用做虚拟轴。
内置的以太网端口可以用来编程,也可以使用通用协议连接HMI和PLC。用户可以通过使用功能强大的MotionPerfect组态编程软件,采用由Trio自己创造的多任务编程语言TrioBasic编写应用程序,轻松实现复杂的运动控制工程。每个轴都可以通过编程实现各类运动类型,如直线运动、圆弧运动、螺旋线运动、球面插补运动、电子凸轮运动、轴间的联动及电子齿轮运动等。
另外,MC405还支持附加的功能选项,通过使用全功能的PLC编程系统,MC403可以实现支持工业标准IEC61131-3程序的实时运行。
通过一个明亮易读的背光显示屏及两个LED灯的闪亮,可以轻松获悉控制器状态,同时底座采用金属外壳,增强了系统的接地能力,提高了系统在工业现场的抗干扰能力。
The MC405 is a high specification Motion Coordinator using a high performance ARM11 processor and provides up to 4 axes of servo plus a master encoder axis or up to 5 axes of stepper control.New from Trio... The MC405
All 5 encoder ports can be either incremental or one of three popular absolute encoder types; SSI, Tamagawa or EnDat, additionally the 5th axis can be used as a stepper, reference encoder input or a sync encoder output.
The MC405 features a total of 16 axes in software. Any axes not assigned to built-in hardware can be used as a virtual axis.
The built-in Ethernet port allows programming and connection of common HMI and PLC protocols directly to the MC405. User programs can be written in Trio’s established multi-tasking TrioBASIC language using the powerful Motion Perfect application development software making complex motion easy. Every axis can be programmed to move using linear, circular or helical or spherical interpolation, electronic cams, linked axes and gearboxes.
Also available as an option on the MC405, the industry standard IEC 61131-3 runtime is an easy to use fully functional PLC programming system. A bright easy to read backlit display enables the controller status to be easily determined, whilst the single piece metal cast backplate provides an integrated earth chassis to improve noise rejection in the industrial environment.
松下Panasonic A4经典系列交流伺服
Trio MC405是一款高性能的运动协调控制器
Trio PCI208基于PC机的PCI总线控制的数字运动控制卡
Trio ME309/EURO209运动控制器
metronix ARS2000直流多功能智能伺服驱动器
