上海萃德推出:Trio MC403运动控制器
MC403具有8个轴的软件功能。任何没有被分配到实际物理轴的轴都可以被用做虚拟轴。
内置的以太网端口可以用来编程,也可以使用通用协议连接HMI和PLC。用户可以通过使用功能强大的MotionPerfect组态编程软件,采用由Trio自己创造的多任务编程语言TrioBasic编写应用程序,轻松实现复杂的运动控制工程。每个轴都可以通过编程实现各类运动类型,如直线运动、圆弧运动、螺旋线运动、球面插补运动、电子凸轮运动、轴间的联动及电子齿轮运动等。
另外,MC403还支持附加的功能选项,通过使用全功能的PLC编程系统,MC403可以实现支持工业标准IEC61131-3程序的实时运行。
通过两个LED灯的闪亮,可以轻松获悉控制器状态,同时底座采用金属外壳,增强了系统的接地性能,提高了系统在工业现场的抗干扰能力。
The MC403 is a high specification Motion Coordinator using a high performance ARM11 processor and provides up to 2 axes of servo plus amasterencoder axis or up to 3 axes of stepper control.
All 3 encoder ports can be either incremental or one of three popular absolute encoder types; SSI, Tamagawa or EnDat, additionally the 3rd axis can be used as a stepper, reference encoder input or a sync encoder output.
The MC403 features a total of 8 axes in software. Any axes not assigned to built-in hardware can be used as a virtual axis.
The built-in Ethernet port allows programming and connection of common HMI and PLC protocols directly to the MC403. User programs can be written in Trio’s established multi-tasking TrioBASIC language using the powerful Motion Perfect application development software making complex motion easy. Every axis can be programmed to move using linear, circular or helical or spherical interpolation, electronic cams, linked axes and gearboxes.
Also available as an option on the MC403, the industry standard IEC 61131-3 runtime is an easy to use fully functional PLC programming system. Two LED's enable the controller status to be easily determined, whilst the single piece metal cast backplate provides an integrated earth chassis to improve noise rejection in the industrial environment.
松下Panasonic A4经典系列交流伺服
Trio MC405是一款高性能的运动协调控制器
Trio PCI208基于PC机的PCI总线控制的数字运动控制卡
Trio ME309/EURO209运动控制器
metronix ARS2000直流多功能智能伺服驱动器
