艾讯宏达板载内存嵌入式主板SYS7F877VGGA-OM上市
艾讯宏达近日隆重推出板载内存4”嵌入式工业主板SYS7F877VGGA-OM主板。SYS7F877VGGA-OM板载2GB DDR3 内存,及英特尔凌动D2550处理器。集成2个千兆网络控制器, 7个USB接口。1个Mini PCIe(支持SIM卡),1个PCI-104,1个mSATA扩展槽。SYS7F877VGGA-OM处理器平贴底部,采用超薄设计,主板整体高度不超过18mm。该主板的这些独特设计,特别适用于车载设备、高铁/地铁自动售票机/闸机等应用领域。
详细规格:
>> System
Processor Onboard Intel Cedar Trail D2550(1.86GHz, 10W) processor (D2500/N2600/N2800 Co-lay)
Chipset Intel NM10
DRAM Onboard 2GB DDR3 1066MHz Memory(N2600 only support DDR3 800MHz)
BIOS AMI Flash ROM
Watchdog Watchdog timer function
Power Supply 12V DC-In, Support AT/ATX mode
Dimension 115mm x 165mm (EPIC form factor)
>> I/O Ports
HDD 1 x SATA 2.0 speed up to 3.0Gb/s Connectors
SSD 1 x mSATA Connectors
Serial Port 6 x COM ports(COM1 Support RS232/422/485 with Auto flow control )
Parallel 1 x Parallel port
Audio Realtek ALC887 HD audio codec with Line-in/MIC/Line-out
LAN 1 x Realtek RTL8111E PCI-E Gigabit LAN
1 x Intel I210AT PCI-E Gigabit LAN
LPT 1 x Printer port , Support EPP/ECP mode
USB 7 x USB2.0
Digital I/O 4 input; 4 output
Expansion 1 x Mini PCIe Expansion Support SIM card , 1 x PCI-104 Slot
>> Display
Graphics Integrated Processor Graphics Engineer with GMA3650
DVI 1x DVI-I Connector (Contain VGA signal)
LVDS Support 24 bit Single channel LVDS Max up to 1440 x 900 @60MHz Resolution
>> Environment
Operation Temperature: 0°~60°C
Storage Temperature: -20°C~80°C
Humidity 10~90%,Non-Condensing
SYS7F877VGGA-OM即将量产上市,欢迎来电咨询!
艾讯宏达金典产品选型目录
艾讯宏达i5系列工业平板电脑PAD6315-i54C
艾讯宏达环保专用平板电脑PAD6315-BTHB
艾讯宏达嵌入式无风扇主机助力搬运机器人的发展
艾讯宏达支持双ISA的B85芯片组ATX主板
