艾讯宏达 B75芯片组工业母板SYM76996VGGA
SYM76996VGGA工业母板,支持LGA1155英特尔酷睿三代i3/i5/i7处理器,采用英特尔B75芯片组,2个英特尔千兆网络控制器。
¨ LGA1155架构,支持英特尔第二代/第三代酷睿 i3/i5/i7/奔腾/赛扬处理器
¨ 英特尔B75 PCH芯片组
¨ 4个240-pin内存插槽,最大支持32GB DDR3 1600Hz内存
¨ 2个英特尔PCI-E千兆网络控制器
¨ 5个SATAII接口,1个SATAIII接口
¨ 6个串口,12个 USB接口
¨ 1个 PCI-E 16x,1 个PCI-E 4x,1 个PCI-E 1x,4个PCI扩展槽
详细规格:
>> System
Processor LGA1155 for Intel® Core i3/i5/i7/Pentium/Celeron Processors,
Support Sandy Bridge and Ivy Bridge CPU
Chipset Intel® B75 PCH (Q77 by Option)
DRAM 4 x 240pin DDR3 1600MHz DIMM up to 32GB
BIOS 8MB AMI Flash ROM
Power Supply Standard ATX power
Watchdog Watchdog timer function
Dimension 305mm x244mm
>> I/O Ports
HDD 1 x SATA 3.0 + 5 x SATA 2.0; (0/1/5/10 RAID support by Q77 Option)
Serial Port 5 x RS232 , 1 x RS232/422/485 COM ports
Parallel 1 x LPT port support with ECP/EPP/SPP mode
Audio Realtek ALC892 High Definition Audio, line-out, line-in and MIC
Keyboard/Mouse 1 x mini-DIN port for PS/2 Keyboard and Mouse
LAN 1 x Intel® 82574LPCI-E Gigabit controller
1 x Intel® 82579V PCI-E Gigabit controller
USB 12 x USB2.0
Digital I/O 1 x 8 bits Digital I/O connector
Expansion 1 x PCI-E 16x, 1 x PCI-E 4x, 1 x PCI-E 1x , 4 x PCI slots
VGA 1x VGA port ,2048x1536 @ 75Hz max Resolution
DVI 1 x DVI-D port ,1920 x 1200@60Hz max Resolution
>> Environment
Operation Temperature 0°~60°C(32°~140°F)
Humidity 10~90%
艾讯宏达金典产品选型目录
艾讯宏达i5系列工业平板电脑PAD6315-i54C
艾讯宏达环保专用平板电脑PAD6315-BTHB
艾讯宏达嵌入式无风扇主机助力搬运机器人的发展
艾讯宏达支持双ISA的B85芯片组ATX主板
