新品速递
美国 Futek USB210传感器
美国 Futek USB210传感器
USB210特点:
*即插即用
*精度高
*体积小
*简化系统
FUTEK公司的USB传感解决方案,适合于所有的应变式传感器,如称重、压力和扭矩传感器等。USB传感解决方案,减少了测量链中的放大器、滤波器、电源等模块,即插即用操作简便。我们提供USB210\USB220\USB320三种产品,以适用于不同的应用场合。
尺寸为inch(mm)
Application
Hydraulic / Pneumatic Press Force Verification / Calibration
Products In Use
Column Load Cells or Load Buttons (LCA/LLB Series) paired with USB Solutions.
View Product Details
Application Summary
Press (Hydraulic or Pneumatic) verification testing is a necessary requirement within the automation process. By implementing load cells with USB output, the operator can verify the uniform loading of a large platform. Each load cell serves as a monitoring point within the system.
How it Works
1. In this application, engineers have installed several LCA or LLB Series Load Cells at the base of this hydraulic press. (Implement enough load cells to quantify the full force capacity of the press)
2. These load cells have been paired with FUTEK's USB modules to stream live measurements onto the engineer's PC.
3. As compressive forces are applied to the LCA/LLB Series Load Cells, FUTEK's USB modules in conjunction with FUTEK's SENSIT Test and Measurement Software can verify if the hydraulic press is accurately performing.
美国 Dytran 1060C 压电式力传感器-电荷型
美国 Futek TRH600 旋转式(动态)扭矩传感器
美国 Dytran 7500A2 电容(DC)型加速度传感器
美国 Dytran 1210C2 压电式力传感器-电荷型
美国 Dytran 1051C 压电式力传感器-电荷型
