新品速递
BXM(D)防爆照明动力配电箱-爱尔意防爆推出新型触摸式
——— BXM(D)防爆照明动力配电箱
BXM(D)防爆照明(动力)配电箱(ⅡB、ⅡC)
适用范围 Application
■1区、2区危险场所。
■ⅡA、ⅡB、IIC类爆炸性气体环境。
◆Can be used in Zone 1 and Zone 2 dangerous places.
◆Can be used in IIA、IIB、IIC group explosive atmosphere.
型号含义Mode implication
产品特点 Featrues
■本产品复合型结构,开关箱采用隔爆型结构,母线箱及出线      ◆ This product is of combined structure,switch box adopts The structrue
  箱采用增安型结构.        of flame-proof,busbar and outlet compartment are of safety increased type.
■铸铝合金外壳,内装高分析断小型断路器,具有过载短路保      ◆ MCB with high breaking capacity is mounted inside the diedcastedAI-alloy shell
  护功能并可根据要求增加漏电保护等功能.                                     Which has the function of protecting of electrical leakage is available as required.
■采用模块结构,各种回路可以自由选择组合.                               ◆ Moulded structure,free combination for each circuit.
■有特殊要求可特制.        ◆  Can be made specially to special requirement.
■钢管或电缆布线均可.        ◆    Suitable for both steelpipe and cable wiring.
■符合GB3836-2000,IEC60079标准要求.                                        ◆ Suitable for GB3836-2000,IEC60079 standard request.
主要技术参数 Main te chnical parameters
                       额定电     主回路额                           主回路总          支路额                            管螺纹 Thread         电缆外径(mm)          防护等级
     型号            压(V)        定电流(A)     支路数       开关数(台)        电流(A)      防爆标志      进线       出线          进线        出线          Protection
    Type           Rated       Rated current   Branch       Switch No.         Branch         Ex-mark        Inlet        Outlet         Inlet       Outlet
                        voltage     of main circuit  number       of main circuit   current
 BXM(D)-4                                                      4                                           1
 BXM(D)-6                                                      6                                           3
 BXM(D)-8          380                63                   8                                           5
 BXM(D)-10                                                   10                                         10
 BXM(D)-12                              ~                   12                                         15                                  G11/4"   G1/2"         Φ12       Φ8                    IP55
 BXM(D)-4K                                                   4                                          20          Exde II CT6       ~             ~                 ~            ~                     *IP65
 BXM(D)-6K                                                   6                                          25                                   G3"       G1'/2"        Φ56    Φ 26
 BXM(D)-8K        220              250                 8                1                        40
 BXM(D)-10K                                                 10                                        50
 BXM(D)-12K                                                 12                                        60
嵌入式加油站LED防爆灯BRE8660(60W-150W)
LED防爆免维护路灯BRE8675(30W-90W)
LED防爆免维护路灯BRE8645(30W-90W)
LED防爆免维护路灯BRE8615(60W-120W)
2W防爆标志灯
