富士电机新型千元级7吋 6万色触摸屏
富士电机新推出 7吋和10.2吋触摸屏功能升级,价格极低.800*600像素,65536色 .DC24V .标配实时时钟和内存.RS-232/485/422接口 .有标配以太网接口
可以连接的PLC一览
Maker | PLC | Path-through | Ladder | |
USB | Ethernet | |||
Allen-Bradley | PLC-5 |
PLC-5(Ethernet) |
SLC500 |
SLC500(Ethernet TCP/IP) |
NET-ENI(SLC500 Ethernet TCP/IP) |
NET-ENI(MicroLogix Ethernet TCP/IP) |
MicroLogix |
MicroLogix(Ethernet TCP/IP) |
ControlLogix/CompactLogix |
ControlLogix(Ethernet) |
Automationdirect | Direct LOGIC(K-Sequence) |
Direct LOGIC(Ethernet UDP/IP) |
Direct LOGIC(Modbus RTU) |
Baumuller | BMx-x-PLC |
BECKOFF | ADS Protocol (Ethernet) |
CIMON | BP Series |
CP Series |
DELTA | DVP series |
EATON Cutler-Hammer | ELC |
EMERSON | EC10/EC20/EC20H (MODBUS RTU) |
FANUC | Power Mate |
FATEK AUTOMATION | FACON FB series |
FUFENG | APC Series Controller |
Fuji Electric | MICREX-F series |
MICREX-F series V4 Compatible |
SPB(N Mode)&FLEX-PC series |
| Y | |
SPB(N Mode)&FLEX-PC CPU |
| Y | |
MICREX-SX SPH/SPB series |
| Y | |
MICREX-SX SPH/SPB CPU | Y | Y | Y | |
MICREX-SX(Ethernet) |
| Y | |
GE Fanuc | 90 series |
90 series(SNP-X) |
90 series(SNP) |
90 series(Ethernet TCP/IP) |
RX3i(Ethernet TCP/IP) |
Hitachi | HIDIC-S10/2alpha,S10mini |
HIDIC-S10/2alpha,S10mini(Ethernet) |
HIDIC-S10/4alpha |
HIDIC-S10V |
HIDIC-S10V(Ethernet) |
Hitachi Industrial Equipment Systems | HIDIC-H |
HIDIC-H (Ethernet) |
HIDIC-EHV |
HIDIC-EHV(Ethernet) |
IDEC | MICRO3 |
MICRO Smart |
MICRO Smart pentra |
Jetter | JetControl Series2/3(Ethernet UDP/IP) |
JTEKT | TOYOPUC |
TOYOPUC(Ethernet) |
TOYOPUC(Ethernet PC10Mode) |
KEYENCE | KZ series link |
KZ-A500 CPU |
KV10/24 CPU |
KV-700 |
KV-700(Ethernet TCP/IP) |
KV-1000 |
KV-1000(Ethernet TCP/IP) |
KV-3000/5000 |
KV-3000/5000(Ethernet TCP/IP) |
KOYO ELECTRONICS | SU/SG |
SR-T(K prt) |
SU/SG(K-Sequence) |
SU/SG(Modbus RTU) |
LS | MASTER-KxxxS |
MASTER-KxxxS CNET |
GLOFA CNET |
GLOFA GM7 CNET |
GLOFA GM series CPU |
GLOFA GM series(Ethernet UDP/IP) |
XGT/XGK series CNET |
XGT/XGK series CPU |
XGT/XGK series(Ethernet) |
XGT/XGI series CNET |
XGT/XGI series CPU |
XGT/XGI series(Ethernet) |
MITSUBISHI ELECTRIC | A series link |
QnA series link |
QnA series(Ethernet) |
QnH(Q) series link |
| Y | |
QnH(Q) series CPU | Y | Y | Y | |
QnU series CPU | Y | Y |
Q00J/00/01 CPU | Y | Y |
QnH(Q) series(Ethernet) |
| Y | |
QnH(Q) series CPU (Multi CPU) | Y | Y | Y | |
QnH(Q) series (Multi CPU) (Ethernet) |
| Y | |
QnH(Q) series link (Multi CPU) |
| Y | |
QnH(Q) series(Ethernet ASCII) |
| Y | |
QnH(Q) series (Multi CPU) (Ethernet ASCII) |
| Y | |
QnU series(Built-in Ethernet) |
L series link |
L series(Built-in Ethernet) |
FX series CPU *1 | Y | Y |
FX2N/1N series CPU | Y | Y |
FX1S series CPU | Y | Y |
FX series link(A prt) |
FX3U/3UC/3G series CPU | Y | Y |
FX3U series (Ethernet) |
FX3U/3UC/3G series link (A prt) |
Alink Net10 |
Q170MCPU(Multi CPU) |
Q170 series(Multi CPU)(Ethernet) |
MODICON | Modbus RTU |
MOELLER | PS4 |
OMRON | SYSMAC C |
SYSMAC CV |
SYSMAC CS1/CJ1 | Y | Y | Y | |
SYSMAC CS1/CJ1 DNA |
SYSMAC CS1/CJ1(Ethernet) |
| Y | |
SYSMAC CS1/CJ1(Ethernet Auto) |
| Y | |
SYSMAC CS1/CJ1 DNA(Ethernet) |
Panasonic | FP Series(RS232C/422) | Y | Y |
FP Series(TCP/IP) |
FP Series(UDP/IP) |
FP-X(TCP/IP) |
RS Automation | NX7/NX Plus Series(70P/700P/CCU ) |
N7/NX Series(70/700/750/CCU) |
NX700 Series(Ethernet) |
X8 Series |
X8 Series(Ethernet) |
SAIA | PCD |
PCD S-BUS(Ethernet) |
SAMSUNG | N_plus |
SECNET |
SHARP | JW series |
JW100/70H COM port |
JW20 COM port |
JW series(Ethernet) |
JW300 series |
JW311/312/321/322 series(Ethernet) |
JW331/332/341/342/352/362 series(Ethernet) |
SINFONIA TECHNOLOGY | SELMART |
Siemens | S5 PG port |
S7 |
S7-200 PPI | Y | Y |
S7-200(Ethernet ISOTCP) |
S7-300/400MPI |
S7-300/400(Ethernet ISOTCP) |
S7-300/400(Ethernet TCP/IP PG protocol) |
S7-1200(Ethernet ISOTCP) |
TI500/505 |
TI500/505 V4 Compatible |
TECO | TP03(MODBUS RTU) |
Telemecanique | TSX Micro |
TOSHIBA | T series/V series(T compatible) |
EX series |
TOSHIBA MACHINE | TC200 |
TOYO DENKI | μGPCsx series |
μGPCsx CPU |
μGPCsx series(Ethernet) |
Turck | BL Series Distributed I/O(MODBUS TCP/IP) |
UNITRONICS | M90/M91/Vision Series(ASCII) |
Vision Series(ASCII Ethernet TCP/IP) |
VIGOR | M series |
Yamatake | MX series |
Yaskawa Electric | MEMOBUS |
CP9200SH/MP900 |
MP2300(MODBUS TCP/IP) |
CP/MP EXPANSION MEMOBUS (UDP/IP) |
MP2000 Series |
MP2000 Series(UDP/IP) |
Yokogawa Electric | FA-M3 | Y | Y | Y |
FA-M3R | Y | Y | Y | |
FA-M3/FA-M3R(Ethernet UDP/IP) |
FA-M3/FA-M3R(Ethernet UDP/IP ASCII) |
FA-M3/FA-M3R(Ethernet TCP/IP) |
FA-M3/FA-M3R(Ethernet TCP/IP ASCII) |
FA-M3V |
FA-M3V(Ethernet) |
FA-M3V(Ethernet ASCII) |
WAGO | 750 series(MODBUS RTU) |
750 series(MODBUS Ethernet) |
Others | L-CPU-B |
MODBUS RTU(Free Format) |
MODBUS RTU EXT Format |
MODBUS ASCII |
MODBUS TCP/IP(Ethernet) |
MODBUS TCP/IP(Ethernet)Sub Station |
MODBUS TCP/IP(Ethernet) EXT Format |
Modbus slave(RTU) |
ModbusTCP/IP slave |
Universal Serial |
Without PLC connection |
V-Link |
*1: Only FX0N supported.
� Y: Supported
可以连接的温控器一览
Maker | PLC |
CHINO | LT400 Series(MODBUS RTU) |
DP1000 | |
DB1000B(MODBUS RTU) | |
KR2000(MODBUS RTU) | |
LT230(MODBUS RTU) | |
LT300(MODBUS RTU) | |
LT830(MODBUS RTU) | |
Fuji Electric | PYX(MODBUS RTU) |
PXR(MODBUS RTU) | |
PXG(MODBUS RTU) | |
PXH(MODBUS RTU) | |
PUM(MODBUS RTU) | |
Gammaflux | TTC2100 |
OMRON | E5AK |
E5AK-T | |
E5AN/E5EN/E5CN/E5GN | |
E5AR/E5ER | |
E5CK | |
E5CN-HT | |
E5EK | |
E5ZD | |
E5ZE | |
E5ZN | |
RKC | SR-Mini(MODBUS RTU) |
CB100/CB400/CB500/CB700/CB900(MODBUS RTU) | |
SR-Mini(Standard Protocol) | |
REX-F400/F700/F900(Standard Protocol) | |
SRV(MODBUS RTU) | |
MA900/MA901(MODBUS RTU) | |
SRZ(MODBUS RTU) | |
FB100/FB400/FB900(MODBUS RTU) | |
SHIMADEN | Shimaden Standard Protocol |
SHIKO TECHNOS | C Series |
FC Series | |
GC Series | |
DCL-33A | |
JCx-300 Series | |
PC-900 | |
PCD-33A | |
ACS-13A | |
ACD/ACR Series | |
WCL-13A | |
TOHO | TTM-000 |
TTM-00BT | |
TTM-200(MODBUS RTU) | |
Yamatake | SDC10 |
SDC20 | |
SDC21 | |
SDC30/31 | |
SDC35/36 | |
SDC40A | |
SDC40G | |
DMC10 | |
DMC50(CTRL) *1 | |
DMC50(COM) | |
AHC2001 | |
AHC2001 DCP31/32 | |
DCP31/32 | |
NX(CPL) | |
NX(Modbus RTU) | |
NX(Modbus TCP/IP) | |
Yokogawa Electric | UT100 |
UT750 | |
UT550 | |
UT520 | |
UT350 | |
UT320 | |
UT2400/2800 | |
UT450 |
*1: Integrated to DMC50(COM).
可以连接的变换器&伺服控制器一览
Maker | PLC |
Bosch Rexroth | IndraDrive |
DELTA TAU DATA SYSTEMS | PMAC |
PMAC(Ethernet TCP/IP) | |
Fuji Electric | FVR-E11S |
FVR-E11S(MODBUS RTU) | |
FVR-C11S(MODBUS RTU) | |
FRENIC5000G11S/P11S | |
FRENIC5000G11S/P11S(MODBUS RTU) | |
FRENIC5000VG7S(MODBUS RTU) | |
FRENIC-HVCA/AQUA(MODBUS RTU) | |
FRENIC-Mini(MODBUS RTU) | |
FRENIC-Eco(MODBUS RTU) | |
FRENIC-Multi(MODBUS RTU) | |
FRENIC MEGA(MODBUS RTU) | |
FRENIC MEGA SERVO(MODBUS RTU) | |
HFR-C9K | |
HFR-C11K | |
FALDIC-alpha Series | |
FALDIC-W Series | |
ALPHA5 (MODBUS RTU) | |
ALPHA5 Smart (MODBUS RTU) | |
Hitachi Industrial Equipment Systems | SJ300 Series |
SJ700 Series | |
MITSUBISHI ELECTRIC | FR-*500 |
FR-V500 | |
MR-J2S-*A | |
MR-J3-*A | |
MR-J3-*T | |
FR-E700 | |
Orientalmotor | High-efficiency AR Series(MODBUS RTU) |
CRK Series(MODBUS RTU) | |
Panasonic | MINAS A4 series |
SANMEI | Cuty Axis |
TOSHIBA | VF-S7 |
VF-S9 | |
VF-S11 | |
VF-A7 | |
VF-AS1 | |
VF-P7 | |
VF-PS1 | |
VF-FS1 | |
VF-nC1 | |
TOSHIBA MACHINE | VELCONIC Series |
可以连接的其他一览
Maker | PLC |
Agilent | 4263 Series |
Banner | PresencePLUS(Ethernet/IP(TCP/IP)) |
Fuji Electric | F-MPC04P(Loader) |
F-MPC Series /FePSU | |
PPMC(MODBUS RTU) | |
PH Series | |
PHR(MODBUS RTU) | |
WA5000 | |
APR-N (MODBUS RTU) | |
WE1MA(Ver.A)(MODBUS RTU) | |
WE1MA(Ver.B)(MODBUS RTU) | |
WSZ Series | |
IAI | X-SEL Controller |
ROBO CYLINDER(RCP2/ERC) | |
ROBO CYLINDER(RCS/E-CON) | |
PCON/ACON/SCON(MODBUS RTU) | |
Koganei | IBFL-TC |
MOOG | J124-04x Series |
M-SYSTEM | R1M Series (MODBUS RTU) |
OMRON | V600/620/680 |
KM20 | |
KM100 | |
Panasonic | KW Series |
LP-400 | |
SanRex | DC AUTO (HKD type) |
SHARP | DS-30D |
DS-32D | |
UNIPULSE | F340A |
F371 | |
F800 | |
F720A | |
YAMAHA | RCX142 |
Others | MODBUS RTU |
MODBUS TCP/IP (Ethernet) |
联系电话:010-68486774
富士 VG7S系列 高性能矢量控制型变频器
富士 UG320HD(Handy POD) 触摸屏
富士 UG230系列 触摸屏
富士 PXR3/4/5/7/9型通用型温度调节器
富士 FALDIC-W系列AC伺服系统
