检测类型 Test type | 透过型 Transmissive type |
型号 Model | NPN集电极开路输出(标准型) NPN open-collector output(Standard type) | FGSM20-08 FGSM20-12 FGSM20-16 | FGSM20-20 FGSM20-24 FGSM20-28 | FGSM20-30 FGSM20-36 FGSM20-40 | FGSM20-44 FGSM20-48 | FGSM40-02 FGSM40-04 FGSM40-06 FGSM40-08 | FGSM40-10 FGSM40-12 FGSM40-14 | FGSM40-16 FGSM40-18 FGSM40-20 | FGSM40-22 FGSM40-24 |
PNP集电极开路输出 PNPopen-collector output | FGSM20-08P FGSM20-12P FGSM20-16P | FGSM20-20P FGSM20-24P FGSM20-28P | FGSM20-30P FGSM20-36P FGSM20-40P | FGSM20-44P FGSM20-48P | FGSM40-02P FGSM40-04P FGSM40-06P FGSM40-08P | FGSM40-10P FGSM40-12P FGSM40-14P | FGSM40-16P FGSM40-18P FGSM40-20P | FGSM40-22P FGSM40-24P |
外型尺寸Overall dimension |  | Fiber optic space:20mm |
|  | Fiber optic space:40mm |
Scanning distance/检测距离 | 0.2-2M(usually use 2m) |
Scanning object/检测物理学体 | Nontransparent object Min.dimension:φ20mm | Nontransparent object Min.dimension:φ40mm |
Optic axis width/光轴间距 | 20mm | 40mm |
Optic axis/光轴数 | 8~48PCS | 4~24PCS |
Scanning width/检测宽度 | 140~940MM | 120~920MM |
Angle of direction/角度指向范围 | Scanning distance: ±3�C above 2m |
Power voltage/电源电压 | 12-24VDC 10% ±(Ripple P-P:Max.10%) |
Protective circuit/保护电路 | Circuit reverse connecting protection |
Current consunmption/电流损耗 | Transmitter:max.80Am,receiver:max.80Am |
Control output/控制输出 | NPN:Load voltage Max.30VDC load current max.100mA Residual volatage max.1VDCPNP:output voltage Max.100mA load current min.(Power supply-2.5)VDC |
Operating mode/动作模式 | Light ON only |
Short circuit protection/短路保护 | Built-in |
Response time/响应时间 | Min.12ms |
Light source/光源 | Infrared light |
Simultaneous mode/同步方式 | Simultaneous mode |
Self-diagnostic/自诊断 | Light source inspection,transmitter/receiver luminescent circuit and output circuit |
