IDEC WindSRV - Software
产品分类:工控软件 物联网 HMI/SCADA 应用层 软件平台
品牌:和泉电气
Key Features:
�Best in class performance, certified OPC and DDE compliant connectivity through RS232, RS485 or Ethernet.
�Analog and discrete I/O support for the whole IDEC programmable logic controller family.
�ASCII input and output support through any of our controllers.
�Demo application using OPC, Excel and the MicroSmart PLC for easy start-up and troubleshooting.
WindSRV - Software to Link PC Applications with IDEC PLCs
This 32-bit software application makes it possible to link your OPC and DDE compliant Windows - based software to any IDEC programmable logic controller, using RS232, RS485, or Ethernet. Now you can interface all of those intelligent devices and let them do the work you used to do yourself.
That means any industrial HMI, SCADA, data acquisition, MES or ERP will connect through WindSRV to a MicroSmart, OpenNet Controller, Micro3, Micro3C, or any legacy PLC. All you have to do is install the server software on your PC running Windows, and you have a low-cost data acquisition and monitoring system using your own computer and IDEC.
爱德克 IDEC-安全解决方案
爱德克IDEC-RFID智能阅读器-KW2D
IDEC Safety 2.0理念构建人与机械在共存环境的安全性
【IDEC新品限时促销】YB系列 树脂开关盒样品免费申领
爱德克推出智能机器管家——爱德克RFID识别系统
