推出全新概念的宽屏酷睿2级便携式工控机E-300W
EMP300W Typical Applications Military base and field operations Field service & diagnostic application in many industries Portable servers & workstations Network and communications testing Field data acquisition Field Presentation tool for board manufacturing Geophysical exploration Factory monitoring/automation Video and audio editing on location
产品分类:工控机 工控机整机 便携式工业PC
品牌:阿科美
The EMP 300W is a robust lunchbox computer built using heavy duty metal to provide tough, go-anywhere unit ideally suitable for harsh/severe environments and mission critical applications. With passive backplane board configurations to choose from the available frull length expansion slots of the EMP 300W can be freely configured with other uniquely designed expansions cards for most applications.
Also desiged for harsh environment operations, the LCD screen of the EMP 300W is guarded with a specially treated anti-glare tempered glass for added protection. Every EMP 300W comes equipped with dual system cooling side fans and easy access to its expansion ports for immediate system upgrade or maintenance. Functional practicality combined with the simple and polished design, the EMP 300W with its extra-rugged construction to sustain bumps and impacted blows is the most cost-effective, durable and efficient portable solution for your mission critical applications.
- All Aluminum Construction
- Built-in 17" TFT LCD Screen with 1920x1200
- P5BLS (EMP300W), mATX (EMP340W), SBC (EMP350), and ATX (EMP370 & EMP390) platforms
- Full length PCI, ISA or PCI/ISA configuration
- Shock-mountated drive bays
- Detachable keyboard
- Transflective technology Sunlight readable LCD (optional)
- A/D board Chipset GENESIS 5621 (EMP350 & EMP370) GENESIS 1601 (EMP390)
Model | EMP300W-S105 | ||
Chassis | External Chassis | Aluminum alloy with rubber corners | |
Internal Chassis | Aluminum alloy frame | ||
System | Chipset | Intel 945GME | |
Form Factor | P5BLS | ||
Display | LCD | 17", 16:10 ratio | |
Resolution | 1920x1200 WUXGA | ||
Color | 262,000 | ||
Brightness/Contrast | 360 nits / 450:1 | ||
Processor | Processor | Intel Core Duo T7200 2.0GHz (DualCore) | |
Cache | 4MB L2 Cache | ||
Memory | RAM | 2GB DDR2 533Mhz | |
Integrated Peripherials | Hard Drive | 1x 250GB SATA 7200RPM 3.5" | |
Optical Drive | 1x IDE DVD-RW Slim | ||
FDD/Cardreader | N/A | ||
Redundancy | RAID | 0, 1, 5, 10 | |
Graphic Controller | Chipset | Intel 945GME (LVDS) | |
Memory | 128MB frame buffer (DDR) | ||
Open Bay | 5.25 | N/A | |
3.5 | 2x 3.5" | ||
2.5 | 1x 2.5" | ||
Expansion | PCI-e | 1x PCI-E (x16) | |
PCI-X | N/A | ||
PCI | 6x PCI | ||
Audio Controller | Chipset | ICH7R + AC97 Codec ALC655 w/5.1 channels NS LM4950 (8-ohm 2W stereo audio amplifier) |
Communication | LAN | 1x ICH7R 10/100BT MAC + Intel 82562ET PHYLAN 1x Intel 82573L PCI Express Gigabit LAN |
Input Peripherial | Keyboard | Full size 108-key keyboard | |
TouchPad | Integrated TouchPad | ||
Integrated interface | USB | 4x external USB ports, USB 2.0 compliant 2x internal USB headers, USB 2.0 compliant |
Firewire | N/A | ||
SATA | ICH7R with 3x ports | ||
IDE | 1x enhanced IDE, UDMA33/66/100 | ||
Parallel Port | 1x parallel port supports SPP/EPP/ECP | ||
Serial Port | 1x RS-232/422/485 1x RS-232 port |
VGA Port | 1x D-sub 15 | ||
Power | Power supply | 270W, mini 1U, 110VAC ~ 220VAC | |
Dimensions | H | 12.01" (305mm) | |
ECP382-P便携式电脑 阿科美FLP200现场型便携机 ACME 新推便携式平台以满足更高的移动数据存储需求和高清视频流应用 ACME II 系列便携式工业PC AFS370工业电脑 |
