M-Systems 高速宽温电子盘
2004/12/16 11:57:00
M-Systems Fast Flash Disk (FFD) 2.5" Ultra ATA Flash Disk is a state-of-the-art solid-state disk, based on NAND flash technology, that provides the functionality of a hard disk with no moving parts.
产品分类:工控机 工控元器件 工控机配件 存储器 存储产品 固态电子盘
品牌:日本爱模系统
·1GB to 128GB disk capacity
·2.5" standard form factor
·ATA-6: Ultra DMA 0-5 ,DMA 0-2 and PIO 0-4 transfer modes
·100.0 MBytes/sec burst read/write rate
·40.0 MBytes/sec sustained read/write rates
·Quick security erase in seconds
·Sanitize confidential data, comply with DoD, NSA , US Air force, Army, Navy and IRIG
·TrueFFS® technology
·>5,000,000 Write/Erase cycles, unlimited Read
·Enhanced endurance by dynamic wear-leveling
·SMART (Self-Monitoring, Analysis and Reporting Technology)
Data integrity under unstable power conditions
·MIL-STD 810F and and NEBS Level 3 compliant
·5 Year Warranty
◆Overview
FFD 2.5" Ultra ATA Flash Disk is an ideal, rugged storage solution for mission-critical applications that must operate under harsh environmental conditions.
FFD 2.5" Ultra ATA Flash Disk delivers outstanding reliability and enhanced endurance thanks to M-SystemsTrueFFS® technology, which applies dynamic wear-leveling and bad block management. Due to its unique design, FFD 2.5" Ultra ATA Flash Disk provides high-performance sustained read and write rates up to 100MB/s and supports Ultra DMA 0-5, DMA 0-2 and PIO 0-4 transfer modes. FFD 2.5" Ultra ATA Flash Disk is fully compatible with the ATA-6 interface, and has the same mechanical dimensions and mounting holes of traditional mechanical disks. It is a true drop-in replacement for rotating 2.5" ATA disks with highest reliability.
M-Systems family of FFDs has been providing rugged, mass storage solutions to an expansive range of industries since 1997. In air force, navy and army installations, it has been field-tested inside data recorders, moving maps, sonar, radar, fire control systems, black boxes, data acquisition systems, C4ISR, telemetry systems, rugged laptops and servers.
Specifications
◆Capacity
·Unformatted (MBytes)
1024, 2048, 4096, 8192, 12288, 16384, 20480, 24576, 32768, 40960, 49152, 57344, 65536, 73728, 81920, 90112, 98304, 106496, 114688, 122880, 131072 (1GB=1024MB).
◆IDE Compatibility
·ANSI- INCITS 361 - ATA-6; ANSI- INCITS 340 - ·ATA-5; ANSI- INCITS 317 - ATA-4; ·ANSI-X3.298-1997 - ATA-3; ANSI-X3.279-1996 - ATA-2
◆Performance
·Burst Read/Write: 100.0 MBytes/sec
·Sustained Read: 45.0 MBytes/sec
·Sustained Write: 40.0 MBytes/sec
·Access time: <0.04 ms
◆Physical
·Form factor:2.5"
·Mounting:Industry standard, 44 pins connector
·Case dimensions:(mm): 100.2(L) X 69.8(W) X 9.4 to 29.9(H)
·Weight:0.1 Kg for 8GB; 0.3 Kg for 128GB
◆Environmental
·Operating temperature
·Commercial: 0°C to +70°C
·Enhanced: -25°C to +75°C
·Extended:-40°C to +85°C
·Storage temperature:-55°C to +95°C
·Humidity:5% to 95% relative, non-condensing
·Operating altitude: Up to 80,000 feet
·Operating shock: 1,500G, MIL-STD-810F
·Operating vibration:16.3G RMS (random, 20Hz to 2000Hz;3 vibration axes), MIL-STD-810F
◆Power
◆Reliability
◆Endurance
·Unlimited read cycles
·TrueFFS® dynamic wear-leveling
·Garbage collection process
>10 years data retention
◆User Interface & Configuration
·Interface:16-bit
·Master/Slave mode: Jumper-selectable
·ATA transfer modes:PIO 0-4; DMA 0-2; UDMA 0-5
·Firmware upgrade:Field upgrade capability
·Format: Factory low-level format
·Drivers:None required
·Power LED:Green
·Access LED:Red
◆Enhanced Security Erase
·Entire disk security erase in seconds
·Partial security erase
·Auto-resume security erase/sanitize on power interrupt
·Power-Free security erase/sanitize
·Sanitize complies with NISPOM DoD 5220.22-M, NSA 130-2, Air Force AFSSI 5020, Army 380-19, Navy NAVSO P-5239-26 and IRIG-106 NTISSP-9
Secure erase/sanitize software interrupt, hardware interrupt optional
◆Compliance
CE, UL, EN 55022 Class B, CISPR 22 Class B, AS/NZS 3548 Class B, BSMI CNS 13438 Class B, CAN/CSA-V-3/2001.04 (VCCI), FCC Part 15 Class B, EN 61000-3-2, EN 61000-3-3, IEC 61000-4-2/3/4/5/6/8/11, MIL-STD-810F
◆Customization
PCB conformal coating
Faster read/write rates
Made in the USA and for FMF
◆Warranty
5 years (longer warranty period can be supported)
◆Ordering Information
FFD-25-UATA-CCCCC-T-H
CCCCC: Unformatted capacity (MB) 1024, 2048, 4096, 8192, 12288, 16384, 20480, 24576, 32768, 40960, 49152, 57344, 65536, 73728, 81920, 90112, 98304, 106496, 114688, 122880, 131072 (1GB=1024MB)
T:
Operating temperature range
Blank - Commercial: 0°C to +70°C
N - Enhanced:-25°C to +75°C
X - Extended:-40°C to +85°C
H: Case Height (mm)
A-9.4mm up to 8GB=8192MB
B-13.4mm up to 32GB=32768MB
C-17.4 mm up to 56GB=57344MB
D-21.4 mm up to 80GB=81920MB
F-29.9 mm up to 128GB=131072MB
·5 Year Warranty
◆Overview
Specifications
◆Capacity
◆IDE Compatibility
◆Performance
◆Physical
·Form factor:2.5"
◆Environmental
◆Power
◆Reliability
◆Endurance
·Interface:16-bit
·Power LED:Green
·Access LED:Red
◆Compliance
◆Customization
◆Warranty
T:
H: Case Height (mm)
处理m-system宽温2.5英寸FFD一批
华高科技最新推出PCIE转1串口1并口卡
华高科技推出新一代44PIN的WINDOM(电子硬盘)
华高:m-systems原装系列DOC电子盘
华高远程 WEB I/O 控制器
