产品选型
全新三屏多功能便携电脑
全新三屏多功能便携电脑
Possible Uses: Audio Editing Software Application GIS Software Application CAD software (SolidWorks) Application Autodesk?3ds Max?Software Application Financial Trading & Services * Software is not included
产品分类:
工控机 工控机整机 便携式工业PC
品牌:
阿科美
Image GTS370-S101
Key Features
  • Three 17" SXGA LCD Panels (3840 x 1024 5ms)
Call Us for the Customization 626.610.1888
Portable Case
The GTS370 is a robust lunchbox computer built using heavy duty metal to provide tough, go-anywhere unit ideally suitable for surround system and video applications. Every GTS370 comes equipped with three high resolution LCD displays, dual system cooling side fans and easy access to its expansion ports for immediate system upgrade or maintenance. Functional practicality combined with the simple and polished design, the GTS370 with its extra-rugged construction to sustain bumps and impacted blows is the most cost-effective, durable and efficient portable solution for your needs.
Instant Setup:
Setting up is no hassle. GTS370 enables you to be up-and-running in seconds without complicated setup. Our all-in-one design has integrated keyboard, mouse, and display into a total package for your convenience.
LCD Display Information:
The GTS370 has built-in three high resolution LCD screens. With our engineering advancement, LCDs can be expanded and retracted fully effortlessly.
The GTS370 is integrated with high brightness, high contrast and fast response LCD screens.
ECP382-P便携式电脑
阿科美FLP200现场型便携机
ACME 新推便携式平台以满足更高的移动数据存储需求和高清视频流应用
ACME II 系列便携式工业PC
AFS370工业电脑
  Model GTS370-S101
Chassis External Chassis Aluminum alloy with rubber corners
Internal Chassis Aluminum alloy frame
System Chipset Intel 5000X Chipset
Form Factor ATX
Display LCD 3 X 17" SXGA, 5ms, 4:3 ratio
Resolution 3x 1280 x 1024, SXGA
