穆尔自动化系统IP20可扩展模块 MBM
2005/11/15 17:31:00
IP20可扩展模块 MBM
产品分类:现场总线 Profibus
品牌:穆尔电子
MBM总线站点
总线站点 Profibus-DP
Bus system MBM
Our MBM system with IP20 protection can be aligned to your requirements. All
applications can be realized with help of modular I/O modules.
Mounting
The unit can be DIN-rail mounted.
Plug in connection technology
The connection is via screw or spring clamp plug in terminals, which allows a fast
module change. Potential terminals can be snapped on, too. Additional terminal
blocks are not necessary.
Diagnostics
The extensive use of LEDs on the module and messages over the field bus to the master
helps to diagnose and locate faults.
Protection against over voltage, over load, short-circuit and
reverse polarity
High levels of protection are achieved through well designed fusing for the
power supply, input and output terminals.
Galvanic separation
All the inputs and outputs are optically isolated from the field bus. The separate
connections of bus nodes and I/O sector make it easy to implement emergency OFF
circuits.
Labelling
The large exchangeable label strip for the signals and the module can be labelled
manually, or with a printer or plotter.
Open bus system
Murrelektronik supports Profibus-DP with the product range MBM.
Module range
The wide range of modules has been designed to cover most industrial
applications.
Certification
All units are certified for the respective bus system. The modules also work with
modules from other manufactures.
总线站点 Profibus-DP
Bus system MBM
Mounting
Diagnostics
reverse polarity
Galvanic separation
circuits.
Labelling
Open bus system
Module range
applications.
Certification
穆尔自动化系统IP67紧凑模块 MVK-MP
穆尔自动化系统 ASI总线设备MVK8
穆尔自动化系统IP67紧凑模块 MVK-P
穆尔自动化系统 ASI总线设备MVK12
穆尔自动化系统IP67紧凑模块 MVK-I
