ICOP Vortex86-6047LV-6S
2011/8/29 11:28:07
128MB/6S/3USB/VGA/LCD/GPIO/AUDIO/LAN/CF
产品分类:品牌:
昭营
规格:
SoC DM&P(SiS) Vortex86? System-on-Chip CPU-166MHz
(Low Voltage)
Real Time Clock with Lithium Battery Backup
Bus PC/104 standard compliant
32-bit x-PCI interface, compatible with PCI Rev.2.2,
PC 98/99
BIOS AMI BIOS
System Memory Onboard 128MB SDRAM
Watchdog Timer Software programmable from 4ms to 1hour
VGA AGP Rev.2.0 compliant
Shared system memory up to 64MB (Default 8 MB)
Support resolution up to 1,280x1,024 true colors
VGA and STN/DSTN/TFT Flat Panel interface support
LAN Realtek 8100B 10/100Mbps Ethernet Controller
Half/Full duplex capability
Audio Fully compliant with AC97 V2.1
Hardware DirectSound accelerator
Flash Disk Support MSTI EmbedDisk Module (16MB and above)
PQI DiskOnModule (16MB and above)
I/O Interface Enhanced IDE port x1
FDD port x1
RS-232 port x5
RS-232/485 port x1
Parallel port x1
USB port x3 (Ver 1.1)
16-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors 2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD connector x1
2.0mm 34-pin box header for FDD x1
2.0mm 26-pin box header for Printer x1
2.0mm 10-pin box header for RS-232 x5
2.0mm 10-pin box header for USB x1
2.0mm 4-pin wafer for Line-in/Line-out/MIC-in x3
2.54mm 2-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
External 15-pin D-Sub female connector for VGA x1
External 9-pin D-Sub male connector for RS-232 x1
External RJ-45 connector for Ethernet x1
External Mini DIN socket for Keyboard/Mouse x1
Type I/II Compact Flash slot x1
Power Requirement Single Voltage +5V @ 980mA
Weight 170g
Board Size 102 X 144mm (4.01 x 5.67 inches)
Operating Temperature -20°C ~ +70°C
(Low Voltage)
PC 98/99
BIOS AMI BIOS
FDD port x1
RS-232 port x5
RS-232/485 port x1
Parallel port x1
16-bit GPIO port x1
Weight 170g
WinCE的软件调试
昭营 eBOX-2310MX-D4C 工业级嵌入式微型计算机
昭营 eBOX-2310MX-JSK 工业级嵌入式微型计算机
昭营 eBOX-2350MX-AP 坚固型导轨式无风扇嵌入式系统
eBOX 2310MX-C85AP 坚固型导轨式无风扇嵌入式系统
