ICOP Vortex86-6074LV
2007/3/13 8:46:00
128MB/2S/2USB/VGA/LCD/AUDIO/2LAN
产品分类:品牌:
昭营
规格:
SoC DM&P(SiS) Vortex86? System-on-Chip CPU-166MHz
(Low Voltage)
Real Time Clock with Lithium Battery Backup
Bus PC/104 standard compliant
BIOS AMI BIOS
System Memory Onboard 128MB SDRAM
Watchdog Timer Software programmable from 4ms to 1hour
VGA AGP Rev.2.0 compliant
Shared system memory up to 64MB (Default 8 MB)
Support resolution up to 1,280x1,024 true colors
VGA and /STN/DSTN/TFT Flat Panel interface support
LAN Realtek 8100B 10/100Mbps Ethernet Controller
Half/Full duplex capability
Audio Fully compliant with AC97 V2.1
Hardware DirectSound accelerator
Flash Disk Support MSTI EmbedDisk Module (16MB and above)
PQI DiskOnModule (16MB and above)
I/O Interface Enhanced IDE port x1
FDD port x1
RS-232 port x1
RS-232/485 port x1
Parallel port x1
USB port x2 (Ver 1.1)
10/100Mbps Ethernet port x2
Connectors 2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 34-pin box header for FDD x1
2.0mm 26-pin box header for Printer x1
2.0mm 10-pin box header for RS-232 x2
2.0mm 10-pin box header for USB x1
2.0mm 10-pin box header for VGA x1
2.0mm 8-pin header for Ethernet x2
2.54mm 5-pin box header for Keyboard x1
2.54mm 5-pin header for Mouse x1
2.0mm 4-pin wafer for Line-in/Line-out/MIC-in x3
2.54mm 2-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
Power Requirement Single Voltage +5V @ 920mA
Weight 112g
Board Size 90 X 96mm (3.54 x 3.77 inches)
Operating Temperature -20°C ~ +70°C
(Low Voltage)
BIOS AMI BIOS
FDD port x1
RS-232 port x1
RS-232/485 port x1
Parallel port x1
Weight 112g
WinCE的软件调试
昭营 eBOX-2310MX-D4C 工业级嵌入式微型计算机
昭营 eBOX-2310MX-JSK 工业级嵌入式微型计算机
昭营 eBOX-2350MX-AP 坚固型导轨式无风扇嵌入式系统
eBOX 2310MX-C85AP 坚固型导轨式无风扇嵌入式系统
