ICOP 6075嵌入式ATX Vortex86单板电脑
2007/4/2 9:33:00
嵌入式Vortex86 166兆赫主频单芯片系统单板电脑,自带1个串口/双以太网口/音频接口/USB接口/64 MB DRAM内存/视频输入/电视输出/可接CRT显示器
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:昭营
规格:
■芯片组 嵌入式Vortex86 166兆赫主频系统,使用单芯片系统实时中央处理器,内置锂电池做为后备。
■BIOS AMI BIOS
■系统内存 144 pin SODIMM Socket
■输入/输出 Enhanced IDE interface
RS232 port x 1
Parallel Port x 1
USB ports x 3
IrDA pin-header for wireless communication
■连接坞 RJ-45 connector for 10/100Base-T x 2
2.0mm 44-pin box header
External 15-pin D-type female VGA connector
RCA Connector
External 6-pin Mini DIN for AT-keyboard
External 6-pin Mini DIN for PS2 Mouse
10-pin box header
26-pin box header
Power push button x 1
■显示 AGP Rev 2.0 Compliant, shared system memory area up to 128MB
CRT/LCD display
Resolution up to 1920 x1440 true colors
■网络 Realtek 8100B Single chip x 2
Full-duplex transfer mode, doubles effective bandwidth
NE2000 compatible with built-in 16KB RAM buffer
Throughput: 10/100 Mbps
■电源要求 Single Voltage +5V @1.7A
Single Voltage +5V w/ACPI function (Advanced Configuration and Power Interface)support
■尺寸 133mm x 111mm
■可操作温度 -20-60C
■音频 AC97 CODEC, full compliant with AC97 V2.1
Internal MIC-in, Line-in and Line-out interface reserved
■看门狗 Software Watchdog Timer
Three 8254 Compatible Programmable 16-bit Counters
■BIOS AMI BIOS
RS232 port x 1
Parallel Port x 1
USB ports x 3
RCA Connector
10-pin box header
26-pin box header
CRT/LCD display
■尺寸 133mm x 111mm
■可操作温度 -20-60C
WinCE的软件调试
昭营 eBOX-2310MX-D4C 工业级嵌入式微型计算机
昭营 eBOX-2310MX-JSK 工业级嵌入式微型计算机
昭营 eBOX-2350MX-AP 坚固型导轨式无风扇嵌入式系统
eBOX 2310MX-C85AP 坚固型导轨式无风扇嵌入式系统
