关键字: | |
产品分类: | 工控机 |
品牌: | 艾讯宏达 |
- 产品简介:
- Intel Celeron-M ULV 1.0GHz On Board Small Size, Low power consumption and economical solution Compact size with high performance High Speed Gigabit LAN Controller High precision touch screen On Board IDE interface, Type II CF Slot
Systems:
CPU Type: Intel Celeron-M ULV 1.0GHz Onboard
Chipset: Intel 855GME+ICH4
DRAM: 1 x 200-pin SO-DIMM, Support DDR333 max up to 1GB
Front Bezel: Aluminum
IP65/NEMA4: Yes
Power Supply: DC 24V 60W Power Supply / AC 100~240V (optional power adaptor)
Dimension : 450×350×107
Weight: 11.5Kg
Certificate: CE/FCC
I/O Ports:
IDE Interface: 1 × 2.5” HDD, 1 × IDE CF Slot Onboard
Audio: ALC202A AC’97 Codec, Interface: Line In / Line Out / MIC in
Serial Port: 4 × COMs, Interface: COM1 for RS232, COM2 for RS232/422/485, with D-Sub
COM3 COM4 for RS232 onboard
Parallel: 1 × Parallel Port (SPP/EPP/ECP)
Keyboard/Mouse: 2 × Switch able for Keyboard and Mouse
LAN: 1 × Gigabit LAN (10M/100M/1000M)
USB: 2 × USB 2.0 ports on rear panel, 2 × USB2.0 ports on board
Brightness Control: VR on rear Panel
Display:
LCD: 17” SXGA TFT LCD
Typical White: 300cd/㎡
Contrast Ratio: 500:1
Viewing Angle: 70/70/70/60 (L/R/U/D)
Touch Screen: 5W Analog resistive (USB interface)
Environment:
Temperature: 0°~40°C
Storage temperature: -20°~65°C
Humidity: Operation Humidity 20~90%, Storage Humidity 20~95%
下一篇:横河DAQWORX 数据采集软件
