产品选型
ATR BM100 模拟量模块
ATR BM100 模拟量模块
The analog calculator is a four-quadrant calculator based on the BM100 universal controller. It has 3 analog inputs for the operands (X, Y , Z, 0...刡10V each), two Control inputs to select the arithmetic operation and one Store input...
产品分类:
品牌:
The analog calculator is a four-quadrant calculator based on the BM100 universal controller. It has 3 analog inputs for the operands (X, Y , Z, 0...刡10V each), two Control inputs to select the arithmetic operation and one Store input, which, when activated, stores the last output value calculated. The modules use a supply voltage of 24 Vdc, with galvanic separation at the analog connections. Easy to mount, the BM 101 simply requires snapping onto TS35 mounting rails
MOELLER PKZ 系列电机保护开关
MOELLER塑壳断路器NZM1-4系列
MOELLER M22按钮和指示灯
MOELLER LZM系列断路器
MOELLER DIL接触器
