关键字: | |
产品分类: | 嵌入式系统 物联网 单板电脑 应用层 嵌入式应用 |
品牌: | 艾讯宏达 |
- 产品简介:
- · Support Intel Socket-M Core 2 Duo / Core Duo / Core Duo LV CPU up to 2.23GHz · Equipped with Intel 945GM Chipset with FSB 667MHz · Memory Supports DDR-Ⅱ667 Up to 2.0GB · Expansion Slot for PCI-E 16X, PCI & ISA
·Processor: Intel Socket-M Core 2 Duo / Core Duo / Core Duo LV
·CPU Frequency: Up to 2.23GHz
·Chipset: Intel 945GM+ICH7R+FWH with FSB 667MHZ
·DRAM: 1 x 200-pin DDRⅡ-667 SO-DIMM, Support max up to 2GB
·BIOS: Phoenix-Award PnP with VGA BIOS
·Display: Intel 945GM Chipset internal VGA share system memory, Support CRT
·IDE Interface: 1 x IDE ATA-100; 4 × SATA
·FDD Interface: 1 × 34-pin Header for FDD
·SSD: 1 × CF
·Serial Port: 2 × COM port, COM1 for RS-232, COM2 for RS-232/422/485
·Parallel Port: 1 × ECP/EPP/SPP support
·Keyboard/Mouse: 2 × PS/2 for mouse and keyboard
·LAN: 2 × Marrvell 88E8053 Gigabit LAN
·USB: 4 × USB 2.0
·Audio: Realtek ALC665 with Line-in / Line-out / MIC, 5.1 Channel
·IrDA: 1 x IrDA Port: Support V1.0 SIR Protocol
·Watchdog: 1~255 secs Watchdog timer selectable w / Reset / NMI
·Power Supply: Standard AT/ATX power
·Operating Temperature: 0°~60°C (32°~140°F)
·Humidity: Operation Humidity 20~90%, Storage Humidity 20~95%
·Dimension: 185mm×122mm(7.28"×4.8")
·SSD: 1 × CF
·USB: 4 × USB 2.0
更多内容请访问 艾讯宏达科技有限公司(http://c.gongkong.com/?cid=1434)
上一篇:意大利帝思 TL46系列标准金属外壳标准型色标传感器
下一篇:罗宾康高压变频器
