ICOP-昭营 VSX-6154嵌入式单版电脑
SoC: DM&P SoC CPU Vortex86SX- 300MHz Real Time Clock with Lithium Battery Backup Cache: L1:16K I-Cache, 16K D-Cache Bus: PC/104 standard compliant BIOS: AMI BIOS System Memory: 32MB/64MB/128MB DDR2 on board
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:昭营
规格
SoC
Cache
Bus
PC-104, PC/104+ (Optional)
BIOS
AMI BIOS
System Memory
128MB DDR2 onboard
Watchdog Timer 0 & 1 Sets
Software programmable from 30.5 µsec. To 512 sec. x 2 sets (Watchdog 1 fully compatible with M6117D
VGA
XGI Volari Z9s Chipset
VGA and TFT Flat Panel Interface Support
Onboard 32MB VGA Memory, support resolution up to
1280 x 1024, 16M colors
LAN
Integrated 10/100Mbps Ethernet
Flash Disk Support
Onboard 2MB SPI Flash Disk
MSTI EmbedDisk Module (16MB and above)
I/O Interface Enhanced IDE port (UltraDMA-100/66/33) x1
RS-232 port x3
RS-232/422/485 port x1
USB port (Ver2.0) x2
Parallel port x1
16-bit GPIO port x1
10/100Mbps Ethernet port x1
Connectors
2.0mm 44-pin box header for IDE x1
2.0mm 44-pin box header for LCD x1
2.0mm 26-pin box header for Printer x1
2.0mm 20-pin box header for 16-bit GPIO x1
2.0mm 10-pin box header for VGA x1
2.0mm 10-pin box header for USB x1
2.0mm 10-pin box header for RS-232 x4
2.0mm 8-pin header for Ethernet x1
2.54mm 5-pin box header for Keyboard x1
2.54mm 5-pin box header for Mouse x1
2.54mm 7-pin header for Redundancy Signal x1
2.54mm 4-pin header for -5V, -12V, +12V, GND, DC-in x1
2.54mm 3-pin header for RS-485 x1
2.54mm 2-pin header for Reset x1
2.54mm 2-pin header for System-Fail-SW x1
1.25mm 6-pin wafer for JTAG x1
Power Requirement
Single Voltage +5V @ 580mA
Weight
83g
Board Size
90 X 96mm (3.54 x 3.77 inches)
Operating Temperature
-20°C ~ +70°C
-40°C ~ +85°C(Optional)
WinCE的软件调试
昭营 eBOX-2310MX-D4C 工业级嵌入式微型计算机
昭营 eBOX-2310MX-JSK 工业级嵌入式微型计算机
昭营 eBOX-2350MX-AP 坚固型导轨式无风扇嵌入式系统
eBOX 2310MX-C85AP 坚固型导轨式无风扇嵌入式系统
