集智达 HDB-42812 刀片服务器
2008/12/30 0:00:00
双核双Opteron刀片
产品分类:工控机 工控机整机 其它
品牌:集智达智能
处理器
Supports AMD Dual Core Opteron 200 Series Processors up to 2.6Ghz with 1MB On-Die Cache
芯片组
AMD 8131/8111
内存
ECC Registered DDR 200/266/333/400 SDRAM
容量
Up to 8GB in Four 184-pin Dimm Sockets
磁盘控制器
Onboard ATA 100 IDE Controller
储存
Supports Two 2.5 ATA 100 IDE HDDs or CompactFlash
图形界面
Onboard ATI Rage XL 8MB VGA Controller
网络
Onboard Two Gigabit Ethernet Ports and One Fast Ethernet Port
扩展槽
Supports One PCI-X 64bit 133mhz Card
I/O 接口
I/O Port, Front Accessible KVM, Serial, Parallel, USB 1.1 Ports
订货信息:
HDB42812I3:Supports AMD Dual Core Processor and 200 series Processor up to 2.6 GHz with 1MB On-Die Cache, Support 64bix ExtensionAMD 8131/8111 ChipsetFour 184-pin DIMM Sockets, up to 8GB DDR 400 ECC SDRAMATI RAGE-XL VGA ControllerTwo Onboard 2.5” ATA100 IDE HDDUP to Two Gigabit Ethernet Ports and One Fast Ethernet PortOne Slot PCI-X Riser Card for 3.3V VIO w/ I/O Panel Cutout
HDB42812I5:Supports AMD Dual Core Processor and 200 series Processor up to 2.6 GHz with 1MB On-Die Cache, Support 64bix ExtensionAMD 8131/8111 ChipsetFour 184-pin DIMM Sockets, up to 8GB DDR 400 ECC SDRAMATI RAGE-XL VGA ControllerTwo Onboard 2.5” ATA100 IDE HDDUP to two Gigabit Ethernet Ports and One Fast Ethernet PortOne Slot PCI-X Riser Card for 5V VIO w/ I/O Panel Cutout
芯片组
AMD 8131/8111
内存
容量
磁盘控制器
储存
图形界面
网络
扩展槽
I/O 接口
订货信息:
集智达网络安全计算机——网闸篇
集智达PCIe扩展网卡4个千兆电口国产网卡芯片标准竖插扩展网卡
集智达重磅推出基于国产化X86架构处理器的高性能网络安全计算机
集智达CTC设备为国铁建设助力
集智达推出基于国产化平台的边缘服务器
