英德斯 PCM-5713 5.25"嵌入式主板
2007/12/2 21:55:00
板载CeleronM CPU,852GM,双网口,4 COM,4 USB
产品分类:嵌入式系统 工控机 物联网 应用层 工控机配件 单板电脑 工业母板 嵌入式应用
品牌:英德斯
特性
◆ 板载Intel® Celeron® M 600 MHz with 512K L2 Cache CPU
◆ Intel® 82852GM Chipset
◆ 一个DDR SDRAM 内存扩展槽(最大到1G)
◆ DVI,2-CH LVDS, Dual View
◆ 双Realtek RTL8100C or Optional Intel® 82551QM/82551ER 10/100Mbps LAN
◆ 1 PCI, 1 Mini PCI, Type I/II CF
◆ 2 SATA, 4 COM, 4 USB 2.0, 16-bit GPIO
◆ 无风扇设计
常规
系统
CPU Onboard Intel® μFC-BGA 479 Celeron® M 600 MHz with 512K L2 Cache
Note: Available in different CPU speeds by request
FSB 400 MHz
BIOS Award 512 KB Flash BIOS
System Chipset Intel® 82852GM GMCH/6300ESB
I/O Chip Winbond W83627HG-AW
System Memory One 184-pin socket supports up to 1 GB DDR 200/266 SDRAM
SSD One CompactFlash Type I/II socket
Watchdog Timer Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor Monitoring system temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion One PCI slot (PCI Rev. 2.2 compliant), one Mini PCI slot
输入/输出
MIO 2 x EIDE (Ultra DMA 100), 2 x SATA, 2 x FDD, 1 x LPT,
3 x RS-232, 1 x RS-232/422/485, 1 x K/B, 1 x Mouse
IrDA 115k bps, IrDA 1.0 compliant
USB 4 x USB 2.0 ports
DIO 16-bit General Purpose I/O for DI and DO
显示
Chipset Intel® 82852GM GMCH integrated Extreme Graphics 2 controller
Display Memory Intel® DVMT 2.1 supports up to 64 MB video memory
Resolution CRT mode: 2048 x 1536 @ 16 bpp (75 Hz)
LCD/Simultaneous mode: 2048 x 1536 @ 16 bpp (75 Hz)
Multiple Display CRT + LVDS, or DVI/TV-out + LVDS, or CRT + DVI
LVDS Dual-channel 18/24-bit LVDS
DVI Chrontel CH7009B DVI transmitter
TV-Out Chrontel CH7009B TV encoder supports both NTSC/PAL
Supports both S-Video and composite video
声卡
AC97 Codec Realtek ALC655 supports 5.1 CH Audio
Audio Interface Mic in, Line in, CD Audio in, Line out
以太网
LAN Dual Realtek RTL8100C
Optional dual Intel® 82551QM/82551ER or Optional dual Realtek RTL8110S Gigabit LAN or Optional dual Intel® 82541PI/82541ER Gigabit LAN
Ethernet Interface 100Base-Tx Fast Ethernet compatible:
Realtek RTL8100C, Intel® 82551QM/82551ER
1000Base-T Fast Ethernet compatible:
Realtek RTL8110S, Intel® 82541PI/82541ER
Realtek RTL8110S, IntelR 82541PI/82541ER
机械&环境
Power Type ATX
Operation Temperature 0~60° C (32~140° F)
Operating Humidity 0%~90% relative humidity, noncondensing
Size ( L x W ) 8" x 5.75" (203 mm x 146 mm)
Weight 0.88 lbs (0.4 Kg)
◆ 无风扇设计
常规
系统
FSB 400 MHz
输入/输出
显示
声卡
以太网
机械&环境
Power Type ATX
英德斯 YCS-6850 无风扇嵌入式控制器
英德斯 PPC-3580 工业平板电脑
英德斯 IPC-8610工控机箱
英德斯 HMI-6124 人机界面
英德斯 PCM-4896L 5.25"嵌入式主板
