英德斯 PCM-5711 5.25"嵌入式主板
2007/12/3 15:26:00
支持Intel P4&赛扬CPU,双网口,6 COM,6 USB
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:英德斯
特性
◆ 支持Intel® Pentium® 4 / Celeron® CPU
◆ Intel® 82845GV Chipset
◆ 一个DDR SDRAM 内存扩展槽(最大到1G)
◆ 2-CH LVDS, Dual View
◆ 双Realtek RTL8100B or Intel® 82551QM/82551ER 10/100Mbps LAN
◆ Optional Intel® 82540EM Gigabit LAN
◆ AC97 Audio, TV-out
◆ 1 PCI, Type I/II CF
◆ 6 COM, 6 USB 2.0
常规
系统
CPU Supports μFC-PGA 478 Intel® Pentium® 4 with FSB 400/533 MHz
Supports μFC-PGA 478 Intel® Celeron® with FSB 400 MHz
FSB 400/533 MHz
BIOS Award 512 KB Flash BIOS
System Chipset Intel® FW82845GV GMCH/FW82801DB ICH4
I/O Chip Winbond W83627HF
System Memory One 184-pin socket supports up to 1 GB DDR 200/266/333 SDRAM
SSD One CompactFlash Type I/II socket
Watchdog Timer Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
Expansion One PCI slot (PCI Rev. 2.2 compliant)
输入/输出
MIO 4 x EIDE (Ultra DMA 100), 2 x FDD, 1 x LPT,
5 x RS-232, 1 x RS-232/422/485, 1 x K/B, 1 x Mouse
IrDA 115k bps, IrDA 1.0 compliant
USB 6 x USB 2.0 ports
显示
Chipset Intel® FW82845GV GMCH integrated Extreme Graphics controller
Display Memory Intel® DVMT 2.0 supports up to 64 MB video memory
Resolution CRT mode: 2048 x 1536 @ 16 bpp (75 Hz)
LCD/Simultaneous mode: 2048 x 1536 @ 16 bpp (75 Hz)
Multiple Display CRT + LVDS, or TV-out + LVDS
VGA/LCD Interface AGP 4X VGA/LCD interface
LVDS Chrontel CH7017A supports dual-channel 18/24-bit LVDS
TV-Out Chrontel CH7009A TV encoder supports both NTSC/PAL
Supports both S-Video and composite video
声卡
Chipset Intel® FW82801DB ICH4
AC97 Codec VIA VT1612A
Audio Interface Mic in, Line in, CD Audio in, Line out
以太网
LAN 1 Realtek RTL8100B
Optional Intel® 82551QM/82551ER
LAN 2 Realtek RTL8100B
Optional Intel® 82551QM/82551ER or Intel® 82540EM Gigabit LAN
Ethernet Interface 100Base-Tx Fast Ethernet compatible: Realtek RTL8100B, Intel® 82551QM/82551ER
1000Base-T Fast Ethernet compatible: Intel® 82540EM
机械&环境
Power Requirement +5 V @ 1.87 A, +12 V @ 3.7 A, + 3.3 V @ 0.25 A (with Intel® Celeron® 2.6 GHz & 256 MB DDR SDRAM)
Power Type AT/ATX
Operation Temperature 0~60° C (32~140° F )
Operating Humidity 0%~90% relative humidity, noncondensing
Size ( L x W ) 8" x 5.75" (203 mm x 146 mm)
Weight 0.88 lbs (0.4 Kg)
◆ 6 COM, 6 USB 2.0
常规
系统
FSB 400/533 MHz
输入/输出
显示
声卡
以太网
机械&环境
Power Type AT/ATX
英德斯 YCS-6850 无风扇嵌入式控制器
英德斯 PPC-3580 工业平板电脑
英德斯 IPC-8610工控机箱
英德斯 HMI-6124 人机界面
英德斯 PCM-4896L 5.25"嵌入式主板
