产品选型
瑞传ABN-194-瑞传网络通讯平台Bypass卡
Quad-Port 64-bit PCI-X Gigabit Ethernet Adaptor with 2nd Generation Bypass Function
产品分类:
工控机 人机界面 低压电器 其它 其它
品牌:
瑞传
特点:
·Configuration of Normal/Bypass mode and WDT time-out period can be deployed by software commands
·Software programmable modes (Bypass, Normal,Open) after reboot
·Two independent bypass segments
·Quad 64-bit Gigabit Ethernet ports based on Intel® 82546GB controllers
·Supports 133MHz PCI-X bus and is backwards compatible with 64/32-bit PCI
·Built-in Watchdog Timer (WDT) to switch Ethernet ports to bypass mode by system hang
·Built with both on-board LED and LED pin-out for LAN status and bypass mode, provides variable LED location for system integration
瑞传 CAR-3002C-2U机架式高效能网络通信应用平台
瑞传 CAR-4212C-2U机架式高效能网络通信应用平台
瑞传科技跻身Intel®嵌入式与通讯联盟Premier Member五强
瑞传新发布1U网络通讯平台-CAR-1201C
瑞傳 CAR-1201C-1U机架式低端网络通信应用平台
