威斯摩 MR-200 GPRS 路由器
2008/6/5 9:48:24
The MR-200 router is an GPRS router designed to be compatible with the current and future requirements of remote telemetry and industrial control systems applications. The unit has an integral Ethernet port and a 25 pin RS-232 serial interface for local connectivity. The Ethernet interface supports Multicasting (IGMP), VLAN, SNMP, SNTP, FTP, SNMP as well as all the standard TCP, UDP and DHCP protocols.
产品分类:工业以太网 物联网 路由器 网络层 接入传输交换产品
品牌:威斯特蒙
The MR-200 router is an GPRS router designed to be compatible with the current and future requirements of remote telemetry and industrial control systems applications. The unit has an integral Ethernet port and a 25 pin RS-232 serial interface for local connectivity. The Ethernet interface supports Multicasting (IGMP), VLAN, SNMP, SNTP, FTP, SNMP as well as all the standard TCP, UDP and DHCP protocols. The inbuilt RS-232 port can be used to connect legacy serial based equipment such as PLCs, RTUs or IEDs. Alternatively the internal serial port can be used as a backup connection to the remote site when used in conjunction with a suitable Westermo Modem. The MR-200 router has an integrated stateful inspection firewall and can support 5 IPSEC VPN (Virtual Private Network) terminations which can be secured using optional 3DES, AES, SSL, SSH encryption, and MD5, SHA1 key exchange protocols. These features ensure that the remote sites can use the latest security technology to resist denial of service attacks and hacking. The VPN’s can be used as a way of increasing security and to create secure tunnels, running between sites. The VPNs can be used to interconnect the sites effectively replacing the requirement for dedicated leased lines. The VPN tunnels can be terminated on either another MR-200 router or on a Westermo DR-250 ADSL router. An optional license for 50 VPN terminations is also available.
GPRS Router
Ethernet port switch
Dual SIM card operation
Integrated RS-232 terminal server port
SNMP management protocol
Firewall
IPsec VPN support (5 tunnels)
VRRP, OSPF, BGP, RIP2 redundant protocols
DIN Rail, wall or shelf mounted
–20ⅹC to +55ⅹC
24 VDC supply
DES • 3DES • AES • SSL • SSH (optional)
GPRS Router
Firewall
–20ⅹC to +55ⅹC
24 VDC supply
Westermo-威斯摩 DDW-220高速以太网扩展器
Westermo 高速SHDSL以太网扩展器
Westermo 太网扩展器 DDW221-222
WESTERMO 红狐狸军用交换机
Lynx 工业以太网交换机
