BCM-必陞科技 MX852GME工业用主板
IntelR852GME uFC-PGA 478 PentiumR 4 / CeleronR Mini ITX Main Board
产品分类:品牌:
必陞科技
●Supports 90nm Intel uFC-PGA 478 Pentium 4 / Celeron CPU
●Intel® 82852GME Chipset
●One DIMM socket supports up to 1 GB DDR 266/333 SDRAM
●DVI, 2-CH LVDS, Dual View
●Realtek ALC655 6 CH Audio, TV-out
●Realtek RTL8110S Gigabit LAN
●1 PCI, 1 mini PCI, Type I/II CF
●6 COM, 6 USB 2.0, 8-bit GPIO
Specifications
System
CPU Supports uFC-PGA 478 Intel Pentium 4/Celeron with FSB 400/533 MHz
FSB 400/533 MHz
BIOS Award 4 Mb Flash BIOS
System Chipset Intel 82852GME GMCH/82801DB ICH4
I/O Chip Winbond® W83627HG-AW
System Memory One 184-pin DIMM socket supports up to 1 GB DDR 266/333 SDRAM
SSD One CompactFlash Type I/II socket
Watchdog Timer Reset: 1 sec.~255 min. and 1 sec. or 1 min./step
H/W Status Monitor Monitoring CPU temperature, voltage, and cooling fan status. Auto throttling control when CPU overheats
Expansion One PCI slot (PCI Rev. 2.2 compliant),one mini PCI slot
I/O
MIO 2 x EIDE (Ultra DMA 100), 1 x FDD , 1 x LPT, 5 x RS-232, 1 x RS-232/422/485, 1 x K/B, 1Mouse
IrDA 115 kbps, IrDA 1.0 compliant
USB 6 x USB 2.0 ports
DIO 8-bit General Purpose I/O for DI and DO
IEEE-1394A ...........
Display
Chipset Intel® FW82852GME GMCH integrated Extreme Graphics 2 controller
Display Memory Intel® DVMT 2.1 supports 64 MB video memory
Resolution CRT mode: 1600 x 1200 @ 32 bpp (85 Hz)
LCD/Simultaneous mode: 1600 x 1200 @ 32 bpp (85 Hz)
Dual Display CRT + LVDS, or DVI/TV-out + LVDS or CRT + DVI
VGA/LCD Interface -
LVDS Intel 852GME supports Single channel 18/24-bit/Dual-channel 36-bit LVDS
DVI Chrontel CH7009B DVI transmitter up to 135M pixels/second
TV-OUT Chrontel CH7009B TV encoder supports both NTSC/PAL
Supports both S-video and composite video
Audio
Chipset Intel® 82801DB ICH4
AC97 Codec Realtek ALC655 supports 5.1 CH AC97 Audio
Audio Interface Mic in, Line in, CD Audio in, Line out
Ethernet
LAN 1 Realtek RTL8100C 10/100 Mbps LAN
LAN 2 Realtek RTL8100C 10/100 Mbps LAN
Ethernet Interface 100Base-T Fast Ethernet compatible: Realtek RTL8100C
Mechanical & Environmental
Power Requirement +5 V @ 1.41 A, +12 V @ 5.19 A, +3.3 V @ 4.84 A, 5Vsb@2.0A (with Intel(R) Pentium(R) 4 2.4GHz & 1GB DDR SDRAM)
Power Type ATX
Operating Temperature 0~60°C (32~140°F)
Operating Humidity 0%~90% relative humidity, non-condensing
Size (L x W) 6.69" x 6.69" (170 mm x 170 mm)
Weight 0.88 lbs (0.4 kg)
Ordering Information
MX852GME
Intel Pentium 4 / Celeron ITX Main Board with VGA, 2-CH LVDS, DVI, TV-out, 5.1 CH Audio, Dual LAN, CF, PCI, 6 COM, 6 USB 2.0, & GPIO
BCM-必陞科技 CompactFlash卡
BCM-必陞科技 FCX231系列 嵌入式系统
BCM-必陞科技 FCX230系列 无风扇嵌入式系统
BCM-必陞科技 ECX331系列 嵌入式系统
BCM-必陞科技 ECX330系列 嵌入式系统
