有刷无铁芯直流—减速箱和减速电机
Torque range of 10.4 mNm (1.47 oz. in.) to 9534 mNm (1350 oz. in.)
Reduction ratio of 5:1 to 49:1
per gear train
Compact design
Compatible with an array of specialty motor offerings
转矩范围 10.4mNm到9534mNm
减速比 5:1到49:1
每齿轮系
结构紧凑
能和大量专业电机连接
Details
Spur gear concept:
Only 1 transmission point per train
Input wheel made of special grade plastics
Planetary concept:
3 or 4 transmission points per train
详细资料
直齿圆柱齿轮概念:
每个系仅1个传动点
输入轮由高级塑料制成
行星构想:
每个系有3到4个传动点
M22 planetary gearheads are built using the metal injection molding process to provide a high output torque of 1.5 Nm. Ratios from 3.67:1 to 903.8:1 are available. Product Specification
• Diameter : 0.87 in
• Ratio : 5:1
• Technology : planetary
• Torque : 1.5 Nm
• Torque : 212.0 oz-in
• Mass : 26.0 g
M22行星齿轮头被用金属粉末注射成型制成,它能提供1.5Nm的高输出转矩。减速比从3.67:1到903.8:1都可达到。
产品说明:
直径:0.87英寸
减速比:5:1
技术:行星齿
转矩:1.5 Nm
转矩:212.0 oz-in
质量:26克
The R10 series gearhead is a multistage planetary gearhead constructed of rugged plastic. With a maximum output torque of 0.10 Nm, the R10 is offered in reduction ratios of 4:1 to 4096:1. Product Specification • Diameter : 0.39 in
• Ratio : 256:1
• Torque : 0.1 Nm
• Torque : 14.0 oz-in
• Mass : 6.0 g
R10系列齿轮头是采用高低不平的塑料的多级行星齿轮头构造。能提供0.10Nm的最大输出转矩,R10提供的减速比从4:1到4096:1。
产品说明:
直径:0.39英寸
减速比:256:1
技术:行星齿
转矩:0.1Nm
转矩:14.0 oz-in
质量:6克
The R13 series is a planetary gearhead constructed of metal. Characterized by its high output torque of .25Nm to size ratio, the R13 is offered in reduction ratios of 5.5:1 to 915:1. Product Specification • Diameter : 0.51 in
• Ratio : 121:1
• Torque : 0.25 Nm
• Torque : 35.0 oz-in
• Mass : 12.0 g
R13系列是金属的行星齿轮头构造。其特点是规格从25Nm开始的高输出转矩。R13能提供减速比是5.5:1到915:1.
产品说明:
直径:0.51英寸
减速比:121:1
技术:行星齿
转矩:0.25Nm
转矩:35.0 oz-in
质量:12克
