圣邦微电子 SGM9114 8MHz 单通道视频驱动器
产品指标 通道数 Single 关断 Y 电源电压(V) 3.0 to 5.5 固定增益(dB) 6 -3dB带宽(MHz) 8 压摆率(V/μs) 33.7 静态电流(mA) 7.0 最小电源抑制比(dB) 52 最小共模抑制比(dB) 温度范围(℃) -40 to 85 轨到轨输入 N 轨到轨输出 Y 封装形式 SOT-23-6L
产品分类:嵌入式系统
品牌:产品介绍
产品描述 |
The SGM9114 is single rail-to-rail 5th order output reconstruction filter with a -3dB bandwidth of 8MHz and a slew rate of 33.7V/μs. Operating from single power supply ranging from 3.0V to 5.5V and sinking an ultra-low 7mA quiescent current, the SGM9114 is ideally suited for low power, battery-operated applications. SGM9114 employs an internal level shift circuit that avoids sync-pulse clipping and allows DC-coupled output. If AC-coupling is preferred, the SGM9114 offers a sag-correction feature that significantly reduces the size of the output coupling capacitor. SGM9114 has a power-down disable feature that reduces the supply current to 0.72μA, dramatically reducing power consumption and prolonging battery life. It is specified over the extended – |
产品特性 |
Ÿ Excellent Video Performance Ÿ 5th Order Reconstruction Filter Ÿ Internal Gain: 6dB
圣邦微电子 SGM8041超低功耗运算放大器 圣邦微电子 SGM8141超低功耗运算放大器 圣邦微电子推出多功能微处理器监测产品SGM706/SGM708 SGM706 Low-Cost, Microprocessor Supervisory Circuit 圣邦微电子 SGM8045运算放大器 |
