圣邦微电子 SGM3129 四通道低压差恒流型白光LED驱动器
产品指标 输入电压范围(V) 2.5 to 5.5 静态电流(μA) 190 关断电流(μA) 1 输出电压纹波(mVp-p ) 效率(%) 开关频率(kHz) SHDN高电平(V) 1.5 SHDN低电平(V) 0.4 Vout启动时间(ms) 封装形式 MSOP8
产品分类:嵌入式系统
品牌:产品介绍
产品描述 |
The SGM3129 low-dropout bias supply for white LEDs is a high-performance alternative to the simple ballast resistors used in conventional white LED designs. It is optimized for low power keypad and portable backlighting applications. The SGM3129 uses an internal resistor to set the bias current for four LEDs, which are matched to ±5%. The SGM3129's advantages over ballast resistors include much lower bias variation with supply voltage variation, significantly lower dropout voltage, and in some applications, significantly improved efficiency. The SGM3129 requires only a 40mV dropout voltage at a 20mA load on each output to match the LED brightness. The SGM3129 is available in Green MSOP8 package. It operates over an ambient temperature range of |
产品特性 |
Ÿ Support up to 4 LEDs Ÿ Low 40mV Dropout at 20mA Ÿ Less than ±5% LED Current Matching
圣邦微电子 SGM8041超低功耗运算放大器 圣邦微电子 SGM8141超低功耗运算放大器 圣邦微电子推出多功能微处理器监测产品SGM706/SGM708 SGM706 Low-Cost, Microprocessor Supervisory Circuit 圣邦微电子 SGM8045运算放大器 |
