System
- Form Factor
EPIC Board
- Processor
Onboard AMD Geode™ LX 800 Processor 500 MHz
- System Memory
Onboard DDR 333 , Max. 512 MB
- Chipset
AMD Geode™ LX 800 + CS5536
- I/O Chipset
SMSC3112i
- Ethernet
Intel 82551IT for 10/100Base-TX, RJ-45 x 2
- BIOS
Award Plug & Play BIOS - 1 MB ROM
- Wake on LAN
- Watchdog Timer
Generates a time-out system resert
- H/W Status Monitoring
Supports Power Supply Voltage, Fan Speed and Temperature Monitoring
- Expansion Interface
PC/104+, Mini-PCI x 1
- Battery
Lithium battery
- Power Requirement
+8.5~19V
- Power Consumption (Typical)
LX 800 500 MHz, DDR 333 512 MB, 1.95A @ 5V
- Board Size
4.5" x 6.5" (115mm x 165mm)
- Gross Weight
1.2 lb (0.5 kg)
- Operating Temperature
-4oF ~ 158oF (-20oC ~ 70oC)
- Storage Temperature
-40oF ~ 176oF (-40oC ~ 80oC)
- Operating Humidity
0%~90% relative humidity, non-condensing
- MTBF (Hours)
Display: Supports CRT/LCD, simultaneous/dual view displays
- Chipset
AMD Geode™ LX 800 + TI SN75LVDS83
- Memory
Shared system memory up to 254 MB
- Resolutions
Up to 1920 x 1440 @ colors for CRT
Up to 1600 x 1200
- LCD Interface
24-bit dual-channel LVDS
I/O
- Storage
EIDE (UDMA 100 for two deviices), SATA x 1, Type II CompactFlash™ x 1
- Serial Port
RS-232 x 1, RS-232/422/485 x 1
- Universal Serial Bus
USB 2.0 x 4
- PS/2 Port
Keyboard + Mouse x 1
- Digtial I/O
Supports 8-bit Digital I/O (Programmable)
- Audio
Line-In/ Line-Out/ CD-In & MIC-In
