研扬 AEC-6520无风扇嵌入式控制器
2010/5/31 13:14:13
研扬AEC-6520无风扇嵌入式控制器宽幅电源输入,外观小巧,强固型构造,低功耗,壁挂式安装。
产品分类:嵌入式系统
品牌:研扬科技
The AEC-6520 utilizes an Intel Celeron M processor (up to 1GHz), and one DDR SODIMM (up to 1GB). This model is equipped with a DC in power connector, a USB2.0 port, a 10/100Base-TX RJ-45 connector, two COM ports, and a VGA port on the front panel. In addition, the AEC-6520 deploys one internal CompactFlash Socket to enlarge storage capacity.
The key feature of the AEC-6520 is the fanless design. Most of the IPC products in the market do not combine both fanless and IP-65 features into one unit. Surprisingly, the AEC-6520 is capable of both these features in a small, compact design. Another fantastic characteristic of the AEC-6520 is the wide operating temperature range. With all these unique functions, the AEC-6520 is ideal for transportation applications and other harsh environments.
The AEC-6520 has withstood tough vibration testing up to 5G rms and is able to wallmounted or stand alone. This longevity and high reliability factor in this embedded controller, which is also compatible with Windows XP, Windows XP Embedded, Windows CE, and Linux Red Ht, is ready for diverse applications.
系统
- 处理器:Intel Celeron M 1.0GHz
- 系统内存:DDR266 SODIMM, 最大1GB
- VGA/键盘/鼠标:DB-15 VGA x 1
- 以太网:10/100 Base-TX以太网, RJ-45 x 1
- SSD:CF插槽x 1
- 串口:COM1: RS-232, COM2: RS-232/422/485
- USB :USB 2.0 x 1
- 监视定时器:支持
- 电源供电:DC 9-30V 输入
- 功耗:Intel® Celeron® M 1.0 GHz 0.87A@12V
- MTBF (小时) :80,000
- 操作系统:Windows XP, Windows XP Embedded, WinCE, Linux, Windows® 7
构造
- 结构:铝挤型外壳
- 颜色:黑色
- 安装:壁挂式
- 尺寸:10.83" x 78.35" x 2.45" (275mm x 199mm x 62mm)
- 包装尺寸:13.23" x 11.57" x 10.24" (336mm x 294mm x 260mm)
- 净重:5.07 lb (2.3 Kg)
环境
- 防尘防水:IP-65认证
- 工作温度:5°F ~ 140°F (-15°C ~ 60°C) (CF)
- 存储温度-40°F ~ 185°F (-40°C ~ 85°C)
- 存储湿度:5~95%@40°C, 无冷凝
- 振动:5 grms/ 5~500Hz/ 随机运行 - CF
- 冲击:50g峰值加速度(持续时间11msec. ) - CF
- EMC :CE/ FCC Class A
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
