研扬 AEC-6920 无风扇嵌入式控制器
研扬 AEC-6920 无风扇嵌入式控制器支持Intel® Core 2 Duo/ Core Duo处理器,1 PCI-E/ 1 PCI,支持宽范围DC/AC电源输入,千兆以太网/4 COM/4 USB/音频/并口/CFD,抗振动和抗冲击设计,安全、理想的机械控制和数据分析平台。
产品分类:嵌入式系统
品牌:研扬科技
The AEC-6920 BOXER 2 Advanced Embedded Control system continues the BOXER design concept but focuses on the fast expanding Machine Automation market. The AEC-6920 can provide one PCI-E x16 slot and one PCI slot for expansion. Therefore AEC-6920ˇs expandable function, compact size combined with fanless design and highly efficient heat conduction mechanism can fulfill any rugged technical application in industrial automation, factory control, test instrumentation and safety surveillance. Intel® Core 2 Duo/ Core Solo processor with up to 2.0GHz combined with fanless design and high performance is widely acceptable and dependable in this market. USB 2.0, Ethernet and 4 Serial ports allow communication with diverse devices with a high transfer rate. Furthermore, the AEC-6920 can concurrently support three tiers of expansion interfaces - PCI, PCMCIA and mini-PCI. These interfaces are fully integrated within the BOXER series and allow an upgrade to their usefulness. It is a leading-edge thermal and vibration design (up to 55 degree operation and 5G RMS vibration) and also an innovation for Machine Automation in the IPC industry. AEC-6920 plays a role in connecting all subsystems in common applications. AAEON not only enhances your competitive value but also gives you an excellent solution for the future. |
系统
- CPU:Intel® Core 2 Duo 处理器
- 系统内存:DDRⅡ SODIMM×1,最大2 GB
- 扩展接口:PCI-E×1,PCI×1,PCMCIA插槽×2
- VGA / 键盘 / 鼠标:DB-15 VGA 接口,PS/2键盘&鼠标
- 以太网:10/100/1000Base-TX RJ-45 接口×2
- SSD:Type Ⅱ CF 卡插槽× 1
- 驱动磁盘器:2.5" 超薄 HDD Bay
- 串口:RS-232×3,RS-232/422/485×1
- 音频:Mic-in / Line-in / Line-out,使用扩展线
- USB:USB 2.0 端口 × 4
- 系统控制:电源开关× 1,重启按钮 × 1
- LED 指示灯:电源指示灯×1,HDD指示灯×1
- 监视定时器:可编程超时中断或系统复位
- 电源:
1. DC输入:内置DC-DC 转换器(默认)
输入电压:9VDC~30VDC
2. AC输入:外置电源适配器(可选)
输入电压:100VAC~240VAC@50~60Hz - 操作系统:Windows® XP,Windows® 2000,Windows® XP Embedded
结构
- 构造:铝挤型外壳,鳍皱散热设计
- 颜色:金黄色
- 安装:壁挂式安装
- 尺寸:214mm(宽)×94.8mm(高)×237.8mm(深)(8.4"×3.7"×9.4")
- 包装尺寸:336mm(宽)×294mm(高)×260mm(深)(13.2"×11.6"×10.2")
- 重量:5.63kg (12.4 lb)
环境
- 工作温度:
-15°C ~ 55°C (5°F ~ 131°F)– Core 2 Duo 2.0GHz (T7200) - CFD
-15°C ~ 50°C (5°F ~ 122°F)– Core 2 Duo 2.0GHz (T7200) - Automotive HDD - 储存温度:-20°C ~ 70°C (-4°F ~ 158°F)
- 储存湿度:5~90%@40°C,无冷凝
- 振动:
5 grms / 5 ~ 500Hz / 随机/运行状态(CFD)
1 grms / 5 ~ 500Hz / 随机/运行状态(内置HDD模块) - 冲击:
50 g 峰值加速度(持续11ms)(CFD)
20 g 峰值加速度(持续11ms)(内置HDD模块) - EMC:CE /FCC A级,UL
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
