研扬 AEC-6860 无风扇嵌入式控制器
研扬 AEC-6860 无风扇嵌入式控制器支持Intel Core 2 Duo处理器,最大支持1.6 GHz;无风扇设计&外观小巧;丰富的视频接口 (VGA, S-video, DVI, LVDS);丰富的IO接口 (USB x 4, COM x 4);支持千兆以太网WLAN, LCD TV, HDTV 分辨率。
产品分类:嵌入式系统
品牌:研扬科技
Due to the growing popularity from the IPC market, the newest Boxer series AEC-6860 has been introduced by AAEON. Compared with the AEC-6850, it is an advanced version because it utilizes an IntelR Core 2 Duo processor without a fan.
New Innovation for Entertainment Multimedia Domain
In this era of information explosion, the advertising of consumer products will not be confined to the family television, but will also spread to high-traffic public areas, like department stores, the bus, transportation station, the supermarket etc. The advertising marketing industry will resort to every conceivable means to transmit product information to consumers. System integrators will need a multifunction device to satisfy commercial needs for such public advertising.
Being a control center, the AEC-6860 is suitable for public multimedia entertainment services. Equipped with a high efficiency heat conduction mechanism
系统
- 处理器
Intel® Core™ 2 Duo处理器, 最大支持1.6 GHz - 内存(选配)
DDR II SODIMM x 1, 最大2 GB - VGA/键盘/鼠标
DB-15 VGA x 1, PS/2键盘&鼠标 - 以太网
千兆以太网, RJ-45 x 1 - 硬盘存储
选配2.5" HDD(SATA) + 超薄CD-ROM模块 (IDE),
选配3.5" HDD模块 (SATA),
选配双2.5" 超薄HDD(SATA) - COM
RS-232 x 3, RS-232/422/485 x 1 - 音频
Mic-in/ Line-in/ Line-out, 需要1条延长线 - USB
USB2.0 x 4 - DVI
DVI-D x 1 - TV-out
S-video - 无线网络
WLAN kit (802.11b/g) (选配) - 系统控制
电源开关 x 1, 复位按钮 x 1 - LED指示灯
电源LED x 1, HDD active LED x 1 - 监视定时器
可通过软件编程超时中断或系统复位 - 供电方式
1. DC输入:
内置DC-DC转换器(默认)
输入电压: 9V DC ~ 30V DC
2. AC输入:
外置电源适配器(选配)
输入电压: 100V AC ~ 240V AC @ 50 ~ 60Hz - 功耗
Intel® Core 2 Duo 1.6 GHz (T5500)
2.63A@12V - MTBF (小时)
50,000 - 操作系统
Windows® CE .NET 5.0, Windows® XP Embedded, Windows® XP, Windows® 7
结构
- 构造
铝挤型外壳,蓝色,带银色条纹 - 安装
壁挂式/ 桌上型 - 尺寸
8.35" (W) x 2.53" (H) x 6.14" (D) (212mm x 64mm x 156mm) - 净重
5.57 lb (2.53 Kg) - 总重
10.34 lb (4.7 Kg) - 包装尺寸
13.22" (W) x 11.57" (H) x 10.24" (D) (336mm x 294mm x 260mm)
环境
- 工作温度
5°F ~ 131°F (-15°C ~ 55°C) – Celeron® M 1.8 GHz - CF
32°F ~ 122°F (0°C ~ 50°C) – Celeron® M 1.8 GHz - 推入式 HDD
备注: 当采用 Intel® Core™ 2 Duo 1.6 GHz 处理器时, 工作温度不能超过50°C。 - 存储温度
-4°F ~ 158°F (-20°C ~ 70°C) - 存储湿度
5 ~ 95% @ 40°C, 无冷凝 - 振动
5 grms / 5 ~ 500Hz /运行状态(CF)
1 g / 5 ~ 500Hz /运行状态 (HDD) - 冲击
100g峰值加速度(持续时间11 msec.) - DC模式 - 跌落测试
92cm (1角, 3边, 6面) - EMC
CE /FCC Class A
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
