研扬 FOX-150多功能防水型平板电脑
研扬FOX-150多功能防水型平板电脑板载Intel低功耗Celeron M 处理器,15" SVGA 彩色TFT LCD显示,IP65防水密封,强光下可读显示带低反光触摸屏,支持Windows® 2000,Windows® XP ,Windows® XP Emdedded,昼夜省电显示模式,适用于车载应用。
产品分类:工控机 工控机整机 平板电脑(PPC)
品牌:研扬科技
FOX-150 Multipurpose & Waterproof panel PC is a high-performance computing and completely fan-less solution for applications in outdoor, semi-outdoor, and harsh indoor environment ,that comes with Intel Celeron M Low Power processor, 15” wide View-angle display (with sunlight readability), Sealing enclosure( 6 sides of IP65 certified) and Water proof I/O connectors for Ethernet , multi-COM port, audio and USB interfaces. In addition, with water resistant bottoms on front panel, FOX has user-friendly interface for brightness control and a variety of optional wireless for real time communication or navigation.
Besides, for system integrators, a simple, complete, compact and highly integrated system helps you smoothly build an industrial grade solution into your applications. By this concept, FOX is design with valuable features (listed in next section) to serve various field of markets such as Vehicle, food factory, slaughter house, Pharmacy Production, Production Plant Hospital Operation Room, and Outdoor KIOSK Public Information Terminal.
With FOX, we believe the end user can optimize the workflow of operations and management in daily business.
系统
- 处理器
Intel®低功耗Celeron® M 1.5 GHz/ 600 MHz - 系统内存
DDR SODIMM x 1, 最大支持1 GB - LCD/CRT控制器
Intel® 852GM + Chrontel7009 - 以太网
Intel® 82562, 10/100Base-TX, 防水RJ-45 x 1 (选配) - 防水I/O接口
RS-232 x 1, RS-232/422/485 x 1, USB 2.0 x 2, 音频(Line-out) (选配) - SSD
IDE 2.5" 硬盘驱动架(抗振)/ CF(内置) - 操作系统
Windows® 2000, Windows® XP Pro Embedded, Windows® XP Embedded
环境
- 结构
密封铝合金外壳 - 颜色
银灰色 - 安装
VESA 75/100mm - 尺寸
16.14" x 14.41" x 2.36" (410mm x 366mm x 60mm) - 总重
19.8 lb (9 kg) - 净重
16.5 lb (7.5 kg)
环境
- 工作温度
-4°F ~ 131°F (-20°C ~ 50°C) - 存储温度
-22°F ~ 158°F (-30°C ~ 70°C) - 存储湿度
10 ~90%@35°C, 无冷凝 - 振动
3G随机运行, 5~500 Hz - 冲击
30G峰值加速度(持续时间11m sec.)/ 运行状态 - 安全性
整机IP-65认证 - EMC
CE/FCC Class A
供电方式
- DC-DC输入, 90W
输入范围: 9V ~ 30V DC
LCD
- 显示
15" TFT- LCD - 最大分辨率
1024 x 768 - 最大色彩数
16.7M彩色 - 点距
0.297 x 0.297 - 亮度(标准)
450 cd/m2 - 视角
160°(H)/160°(V) - 背光MTBF (小时)
50,000
触摸屏
- 类型
8线, 低反光电阻式 (FOX-150STT)
5线, 电阻式 (FOX-150HTT) - 分辨率
2048 x 2048 - 透光率
> 76% (8线电阻式)
> 80% (5线电阻式) - 寿命
2百次激活(8线电阻式)
3千5百万次激活(5线电阻式)
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
