研扬 POP-190 POP平板电脑
2010/4/16 13:23:07
研扬POP-190 POP平板电脑板载Intel Celeron M 低压处理器;19" WXVGA彩色TFT LCD 显示;开放式结构设计;经济型解决方案。 支
产品分类:工控机 工控机整机 平板电脑(PPC)
品牌:研扬科技
The POP-190 Point of Promotion Panel PC is an Intel® 600MHz/ 1.5GHz processor computer that is designed to serve as a Digital signage market. It is a PC-based system with 19" color TFT LCD display, on-board Ethernet controller, multi-COM port interfaces and an audio controller. With a built-in Compact Flash socket, the POP-190 is as user friendly and multi-function computer. In addition, its Open-frame design makes it fitted to a variety of cutout installation in building & public field. In addition, it can be wall mounted or DIN Rail mounted.
For system integrators, this simple, complete, compact and highly integrated system let you easily build a point of promotion into your applications. Common industrial applications include factory automation systems, precision machinery, and production process control. It is also suitable for many non-industrial applications, including vending machine, and car park automation. Our point of promotion panel pc is a reliable & cost-effective solution to your daily business.
系统
- 处理器: Intel Celeron M 1.5GHz /600MHz
- 系统内存: 512 MB
- LCD/CRT 控制器: Intel 852GM
- 以太网: 10/100Base -TX, RJ-45 x 1(选配)
- I/O 接口:
RS-232 x1, RS-232/422/485x1
USB2.0 x 2
音频 Line out x 1(选配)
PS/2 x 1 (键盘+鼠标)
VGA 输出 x 1 - 存储驱动器: 2.5" HDD支架 /CF插槽(内置)
- 扩展插槽: Mini PCI插槽 x 1 (内置)
- 操作系统: Windows 2000, Windows XP , Windows XP Embedded
结构
- 构造: 开放式
- 颜色: SGCC 金属色
- 安装: VESA 100
- 尺寸: 488mm x 328mm x 63mm (19.21" x 12.91" x 2.48")
- 总重: 8Kg(17.6 lb)
- 净重: 6.5Kg(14.3 lb)
环境
- 工作温度: 0oC ~ 40oC (32oF ~ 104oF)
- 存储温度: -20oC ~ 60oC(-4oF ~ 140oF)
- 存储湿度: 10% - 90%@ 40oC,无冷凝
- EMC: CE/ FCC Class A
电源
- DC-DC 输入
输入范围: 9V~30VDC
LCD
- 显示类型: 19" TFT-LCD
- 最大分辨率: 1440x900
- 最大色彩: 16.7M 彩色
- 点距: 0.2835 x 0.2835
- 亮度: 300 cd/m2
- 视角: 160o(H)/160o(V)
- 背光 MTBF: 50,000
触摸屏
- 类型: 5线,电阻式
- 分辨率: 2048 x 2048
- 透光率: 80%
- 寿命: 3.5千万次激活
官宣!研扬人工智能馆盛大开业啦~
研扬科技BOXER-6405U智能边缘计算平台
研扬科技 | 应用案例分享 || 将边缘计算引入面部识别应用
研扬科技 | FWS-8600网络设备为人工智能网络和数据中心注入新动力
研扬科技 | 由英特尔酷睿处理器驱动的紧凑型完整解决方案
