控易 EmCORE-v615 5.25寸单板计算机
控易 EmCORE-v615 5.25寸单板计算机 VIA 低功耗 Eden 300MHz(ESP3000) 最高 1GHz(ESP10K) CPU, FSB66/100/133MHz;板载 128MB SDRAM 和 1 x 144Pin SO-DIMM 插槽, 合计支持 640MB SDRAM。
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:控易电子
» 板载 128MB SDRAM 和 1 x 144Pin SO-DIMM 插槽, 合计支持 640MB SDRAM
» UMA Savage 4 (VT8606T) AGP 视频控制器, 支持 TTL、LVDS、CRT 显示和 TV-输出(子板支持)
» 单或三个 10/100Mbps 网卡, Intel 82559 或 RTL8100L
» 功耗小于12瓦
General Specifications
• CPU : VIA Ultra Low Power Embedded Eden 400 ~ 800MHz processor with FSB 66/100/133 MHz EBGA package.
• Chipset : VIA VT8606 TwisterT with Integrated Savage4 AGP 4X Graphics core and VT82C686B Super "South Bridge"
• BIOS : AWARD® Flash BIOS
• Green Function : power saving supported in BIOS. DOZE / STANDBY / SUSPEND modes, ACPI & APM
• L1 Cache : Integrated on CPU (128KB)
• L2 Cache : Integrated on CPU (64 KB)
• DRAM Memory : Onboard 128 / 256MB SDRAM, and up to 512MB of SDRAM on SODIMM (Total of 768MB Memory)
• Enhanced IDE with UltraDMA : supports 2 ports and up to 4 ATAPI devices, Ultra DMA transfer 33 / 66 and 100 MB/sec. One 40-pin (2.54 pitch) box header and one 44-pin (2.0 pitch) box header.
• Watchdog Timer : 127-level timer generates RESET or NMI when your application loses control over the system.
• Real-time Clock : built-in chipset with lithium battery backup. CMOS data backup of BIOS setup and BIOS default. High Speed Multi I/O
• Chipset : VIA VT82C686B
• Serial Ports : Three high speed RS-232C ports (COM1). One high speed RS-232C/422/485 port COM2 (jumper selectable). Both with 16C550 compatible UART and 16 byte FIFO.
• USB : 4 onboard USB ver 1.1 ports
• SIR Interface : onboard IrDA TX/RX port
• Floppy Disk Drive Interface : 2 floppy disk drives, 3½" (720 KB, 1.44 MB or 2.88 MB).
• Bi-directional Parallel Port : SPP, EPP and ECP mode.
• Keyboard and Mouse Connectors : external mini-DIN headers for PS/2 KB/Mouse port
• Audio Chipset: VIA VT82C686B, AC97 2.0 compliant, Multistream Direct Sound and Direct Sound 3D acceleration. (Line-in, CD Audio in, MIC in, Speaker out)
Network Interface Controller
• Chipset : 3 x Intel 82559, 10/100 Mbps (EmCORE-v615VL3/N Series) or 3 x Realtek 8139C, 10/100 Mbps (EmCORE-v615VL3/R Series)
• Connector : external RJ-45 with LEDs on bracket Display Controller
• Chipset : 4x AGP S3 Savage4 3D and S3 Savage 2000 2D engines integrated in VT8606 supports up to 32MB of Shared Memory
• Display Type : CRT (VGA, SVGA, XGA, SXGA) and LCD (optional, see LCD Daughterboard) Type
• Connectors : external DB15 for CRT on bracket
• LCD Display Daughterboard (optional) :
- SCDB-1221 - Daughterboard w/ TTL / LVDS / TV-Out
• Resolution: Single Channel of LVDS and 36-bit of TTL; all resolutions are supported up to 1280x1024.
SSD Interfaces
• DiskOnChip (DOC)
- Package : Single Chip Flash Disk in 32-pin DIP JEDEC
- Capacity : up to 288 MByte
- Data Reliability : ECC/EDC error correction
- Memory Window : 8 KByte
• Compact Flash Card (CFC)
- Compact Flash Socket : supports Type I/II CFC
- Capacity : up to 512MB CFC
控易 基于PICMG2.9规范在CompactPCI平台上实现系统管理说明
控易 CER-IRC10加固计算机
控易电子 CER-IRC10 嵌入式整机
控易 CER-ST航海信息仪
控易电子 CER-1027 嵌入式主板
