控易 EmCORE-i6415 5.25寸单板计算机
控易EmCORE-i6415 5.25寸单板计算机支持Intel Pentium 4 Socket 478 CPU 最高 3.06GHz FSB400/533MHz;1 x 184-pin DIMM 插槽, 最高支持 1GB DDR SDRAM;ATI M7 VGA 芯片组, 支持 CRT, LVDS, DVI (TMDS) 和 TV-输出。
产品分类:嵌入式系统 物联网 单板电脑 应用层 嵌入式应用
品牌:控易电子
» Intel Pentium 4 Socket 478 CPU 最高 3.06GHz FSB400/533MHz
» 1 x 184-pin DIMM 插槽, 最高支持 1GB DDR SDRAM
» ATI M7 VGA 芯片组, 支持 CRT, LVDS, DVI (TMDS) 和 TV-输出
» 支持双显示
» 10/100Mbps 网卡或千兆网卡
» 4 x USB 2.0 兼容
» Mini PCI 插槽可用于无线网卡
General Specifications
• CPU : PGA 478 for Intel Pentium 4 with data transfer rate of 400Mhz /533Mhz
• Chipset : Intel 845GV(EmCORE-i6415VL)
•ICH4 South Bridge Intel 845PE, ATI M7 (EmCORE-i6415VLGA)
•ICH4 South Bridge
• BIOS : AWARD® Flash BIOS
• Green Function : power saving supported in BIOS. DOZE / Suspend modes, ACPI,APM
• L1 Cache : Integrated on CPU
• L2 Cache : Integrated on CPU
• DRAM Memory : One DDR socket supports PC2100/PC2700 DDR266/DDR333 up to 1GB
• Enhanced IDE with UltraDMA : supports 2 port (one is 40-pin DMA100, the other is 44-pin DMA33) and up to 4 ATAPI devices, Ultra DMA transfer 100/33 MB/sec.
• Watchdog Timer : 254 level, system reset or NMI High Speed Multi I/O
• Chipset : Winbond 83627HF
• Serial Ports : Three high speed RS-232C ports (COM1 / COM3 / COM4). One high speed RS-232C/422/485 port COM2 (jumper selectable). Both with 16C550 compatible UART.
• USB : 4 onboard USB ports Ver 2.0
• Floppy Disk Drive Interface : One port and up to 2 floppy disk drives
• Bi-directional Parallel Port : SPP, EPP and ECP mode.
• Keyboard and Mouse Connectors : external PS/2 KB/Mouse port (6-pin wafer)
• Audio Chipset: ICH4 integrated audio with AC'97 Codec Audio Interactive (MIC in, Line-in, Speaker out, AC'97 ver. 2.3) Network Interface Controller
• Chipset : ICH4 integrated Ethernet, 10/100 Base-Tx (EmCore-i6415VL) or Intel 82540EM Gigabit LAN (EmCore-6415VLGA)
• Connector : 9-pin header Display Controller
• Chipset : 845GV (EmCORE-i6415VL), ATI M7 (EmCORE-i6415VLGA)
• Display Type : CRT (VGA, SVGA, XGA, SXGA) and LCD
• Connectors : external DB15 for CRT on-board, LCD interface supports LVDS & TMDS
• Resolution:
控易 基于PICMG2.9规范在CompactPCI平台上实现系统管理说明
控易 CER-IRC10加固计算机
控易电子 CER-IRC10 嵌入式整机
控易 CER-ST航海信息仪
控易电子 CER-1027 嵌入式主板
